Hello! My cloudflare stopped working after updating home assistant core to 2023.5. I opened a github issue, but I was directed to post here, so I would appreciate any help.
Github issue: Cloudflare Integration, could not connect. · Issue #86203 · home-assistant/core · GitHub
The problem
After updating to the latest version of home assistant OS (from 2023.4 to 2023.5), the cloudflare integration stopped working (it had worked before).
This is the error log I got:
2023-01-17 21:39:04.615 WARNING (MainThread) [homeassistant.config_entries] Config entry '<my domain>' for cloudflare integration not ready yet: Could not get zone ID; Retrying in background
I tried generating a new token and delete the integration to set it up again with the new token, but that does not work. This is the error message I am getting now: (The form clears the token after adding it)
Could this be a network issue? Some configuration issue in cloudflare?
Thank you!
What version of Home Assistant Core has the issue?
2023.1.5
What was the last working version of Home Assistant Core?
2023.1.4
What type of installation are you running?
Home Assistant OS
Integration causing the issue
cloudflare
Link to integration documentation on our website
Diagnostics information
2023-01-17 21:39:53.784 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Timeout fetching homeassistant_alerts data
