Help develop addon
Hi.
I’m trying to develop an addon starting from my python script. It requires just python and paho-mqtt.
The script works fine on my linux machine, since a week, so i started to move the script into an addon for let it run directly on hass.
I follow the template and make a Dockerfile, run.sh etc.
The installation fail with this error:
1/13 : ARG BUILD_FROM
Step 2/13 : FROM $BUILD_FROM
—> 33c8dcdbe590
Step 3/13 : ENV LANG C.UTF-8
—> Using cache
—> b9b943a75171
Step 4/13 : SHELL [“/bin/bash”, “-o”, “pipefail”, “-c”]
—> Using cache
—> 65973fae1858
Step 5/13 : RUN apk add --no-cache python3 py3-pip && pip3 install paho-mqtt COPY run.sh /
—> Running in c7ffbb59e5f0
fetch https://dl-cdn.alpinelinux.org/alpine/v3.16/main/aarch64/APKINDEX.tar.gz
fetch https://dl-cdn.alpinelinux.org/alpine/v3.16/community/aarch64/APKINDEX.tar.gz
(1/21) Installing libbz2 (1.0.8-r1)
(2/21) Installing expat (2.4.9-r0)
(3/21) Installing libffi (3.4.2-r1)
(4/21) Installing gdbm (1.23-r0)
(5/21) Installing libgcc (11.2.1_git20220219-r2)
(6/21) Installing libstdc++ (11.2.1_git20220219-r2)
(7/21) Installing mpdecimal (2.5.1-r1)
(8/21) Installing sqlite-libs (3.38.5-r0)
(9/21) Installing python3 (3.10.5-r0)
(10/21) Installing py3-contextlib2 (21.6.0-r2)
(11/21) Installing py3-tomli (2.0.1-r1)
(12/21) Installing py3-pep517 (0.12.0-r2)
(13/21) Installing py3-six (1.16.0-r1)
(14/21) Installing py3-retrying (1.3.3-r3)
(15/21) Installing py3-appdirs (1.4.4-r3)
(16/21) Installing py3-more-itertools (8.13.0-r0)
(17/21) Installing py3-ordered-set (4.0.2-r3)
(18/21) Installing py3-parsing (2.4.7-r3)
(19/21) Installing py3-packaging (21.3-r0)
(20/21) Installing py3-setuptools (59.4.0-r0)
(21/21) Installing py3-pip (22.1.1-r0)
Executing busybox-1.35.0-r17.trigger
OK: 91 MiB in 61 packages
ERROR: Directory ‘/’ is not installable. Neither ‘setup.py’ nor ‘pyproject.toml’ found.
Removing intermediate container c7ffbb59e5f0`
So the problem, if i inderstood, is from the Dockerfile:
> ARG BUILD_FROM
> FROM $BUILD_FROM
> ENV LANG C.UTF-8
> SHELL ["/bin/bash", "-o", "pipefail", "-c"]
> # Install requirements for add-on
> RUN \
>     apk add --no-cache \
>          python3 \
>              py3-pip \
>      && pip3 install paho-mqtt \
> # Copy data for add-on
> COPY run.sh /
> COPY pws_server.py /
> RUN chmod a+x /run.sh
> CMD [ "/run.sh" ]
Someone can help me?
Copy rootfs is what you want. It will copy the rootfs files from your repo.
Mine is down below… Although mine isn’t necessarily great…
Hi @HasQT thanks for your support. I tried adding COPY root / and also to add and remove mine COPY commands, same error:
>     RUN     apk add --no-cache 	 python3              py3-pip           && pip3 install paho-mqtt COPY rootfs /
> [WARNING]: Empty continuation lines will become errors in a future release.
> Step 1/12 : ARG BUILD_FROM
> Step 2/12 : FROM $BUILD_FROM
>  ---> 33c8dcdbe590
> Step 3/12 : ENV LANG C.UTF-8
>  ---> Using cache
>  ---> b9b943a75171
> Step 4/12 : SHELL ["/bin/bash", "-o", "pipefail", "-c"]
>  ---> Using cache
>  ---> 65973fae1858
> Step 5/12 : RUN     apk add --no-cache 	 python3              py3-pip           && pip3 install paho-mqtt COPY rootfs /
>  ---> Running in 660b593ac41f
> ERROR: Directory '/' is not installable. Neither 'setup.py' nor 'pyproject.toml' found.
> Removing intermediate container 660b593ac41f
I guess it would probably help if you shared more of your addon. Is there a repo somewhere? Or at the very least what’s in your build.yaml so its clear how $BUILD_FROM is being set.
Also if you aren’t using it there’s an alpine addon base image that comes with python and pip already installed here. If you use that as your base all you have to do is install paho-mqtt via pip.
should be
you don’t need the \ as it is the last command
Yep, this let the addon to install. Thanks, now i try to make it works and make the configuration interactive.
Can you share your code, i try to build an addon in python too
THX!
Sure, you can find what i did on github:
https://github.com/Condorello/HASS_wu_interceptor
