Help disabling the wifi and bluetooth on Yellow with a CM4
Hello I was wondering if anyone can help me?
I’ve got a Home Assistant Yellow with a CM4108032 that has built in wifi and bluetooth.
I’ve been having some issues with ZHA and NETWORK_BUSY being logged and I want to disable the onboard radios on the CM4. I’ve used the nmcli to disable both WIFI and WWAN but I was wondering if there is a way to to properly disable things in a similar way to the RaspberryPI’s boot.txt file?
If someone can let me know it’d be a great help.
Thanks,
Ben.
Anyone have an idea? :thinking:
Hey man, did you get this figured out?
Try edit the config.txt
https://linuxhint.com/disable-wifi-raspberry-pi-through-terminal/
Hi Benjamin.
I also have a yellow with CM4108032. I have trouble with Zigbee nodes dropping out and also slow Z-wave respons. Thought maybe it could be the CM4 internal radio disturbing? Where you able to disable wifi and did it solve your problems?
Regards Kjell
Curious to know if a solution was found by @benjaml or others?
I’m running Home Assistant Supervised on a Raspberry Pi 4 w/ Debian 12, and I seem to only be able to do it using rfkill.
I’m thinking of buying a Yellow and would like an answer before selecting my CM4.
Thanks!
I figured it out and documented my solution here:
