I’m looking for help with an issue I’ve been struggling with for a few days. I have Grafana installed as the official add-on inside Home Assistant, and I want to display Grafana dashboards in Lovelace using an iframe card.
The goal is to make these dashboards accessible to any HA user (non-technical), whether they are:
accessing internally
accessing externally via HTTPS domain (home.xxx.xx)
using a browser or the Companion App (iOS/Android)
Current setup:
HAOS running on a local machine
Official Grafana add-on installed
InfluxDB also installed as an add-on and connected to Grafana
HA is accessible via HTTPS using Nginx Proxy Manager (running outside HA, on CasaOS)
I also get issues related to X-Frame-Options, Content-Security-Policy, or problems with subpath configuration, even though I set GF_SERVER_ROOT_URL and GF_SERVER_SERVE_FROM_SUB_PATH correctly
If I try to use an http:// link in the iframe, it’s blocked due to mixed content (since HA is served over https://)
What I do not want:
I don’t want to expose Grafana outside of HA as a standalone container, because that would cause new problems with InfluxDB connectivity (which lives inside HA)
I don’t want users to log into Grafana — the goal is to use anonymous mode with viewer permissions
I’ve tried multiple configurations in Nginx, HA, and Grafana’s environment variables, but I haven’t found a working setup that allows embedding dashboards in all access scenarios.
Has anyone successfully achieved this or has a working config to share?
Thank you for all your help and patience. Unfortunately, enabling SSL on the Grafana add-on didn’t change anything.
As you can probably tell, I’m not an expert , so I might have left out some information that could help clarify my network setup. Apologies in advance for being overly detailed.
My Home Assistant is accessible externally both via Nabu Casa (just as a failsafe) and via my self-managed domain (https://home.xxxxxxx.xxx). I use Cloudflare + Nginx + Let’s Encrypt to manage the external address. On my private network, I use Pi-hole to manage DNS, allowing internal traffic to be routed to the external address.
So, I always use the address https://home.xxxxxxx.xxx to access Home Assistant via browser or the companion app, whether I’m on the local network or not.
While reviewing the configuration for this post, I found an error in the companion app settings (it was configured to connect via IP instead of the domain when on the local network), which resolved the net::ERR_BLOCKED_BY_RESPONSE error.
To sum it all up: whether SSL is enabled on the Grafana add-on or not, I always get a 401: unauthorized in every scenario—unless I visit the Grafana web interface first.
Thank you once again for all your help and patience
Hi - did you find a solution? I am stuck at the same spot: cannot display the Grafana graphs as dashboard embeddings when using the companion app (and relying on nabu casa).
I’ve been very busy in the last days and I wasn’t able to proceed with this issue, but something has changed (probably an update on companion app) because today in companion app, with my admin account and either in local or external networks I’m able to access the grafana graphics on my dashboard.
But with a “normal” user it still gets unauthorized.
P.S: I didn’t make the auto login configuration as suggested by @Mikefila
Para los que no usan Grafana como Addon y si como contenedor separado de HA. Tienen agregar “GF_SECURITY_ALLOW_EMBEDDING=true”, a su contenedor Docker.
