So when I run ‘Check config’, I get the following error:
Invalid config for [script]: expected dict for dictionary value @ data['script']['1584676433232']['sequence'][7]['data']. Got None. (See /config/configuration.yaml, line 21).
And the error seems to point to this script:
'1584676433232':
alias: Sunrise - CDN
sequence:
- data:
brightness: 1
rgb_color:
- 98
- 19
- 0
entity_id: light.lumiere_du_chevet
service: light.turn_on
- delay: 00:00:01
- data:
brightness: 103
rgb_color:
- 243
- 123
- 0
transition: 400
- delay: 00:06:40
- data:
brightness: 255
rgb_color:
- 255
- 178
- 67
transition: 800
- delay: 00:13:20
- delay: 01:15:00
- data:
service: light.turn_off
But I can’t figure out what I’m doing wrong! What does expected dict for dictionary value @ data['script']['1584676433232']['sequence'][7]['data']. Got None.
stands for? Where in that code am I supposed to look for the error? I don’t get it!
Please help, thanks.
