Hi, I have a small ESP-01 that i want to just connect a button to and controll things in Home Assistant.I just want the button to be pressed, and then a home assistant action happens and then it resets itself, have tried some confiurasions but i am totally lost.
AKA a momentary push button to toggle/turn on/off something in Home Assistant ( I will do this in Home Assistant)
You can do this easily with tasmota and button topics but i want to do it with ESPHomeYaml.
If you already have tasmota installed then it’s easy to load esphomeyaml firmware to it, then you will be able to do OTA updates. I found that using the HA interface to compile was way too slow so I installed python on a windows machine and did a pip install of the esphomeyaml software. Compiles and updates after that only took a few minutes, plus if the OTA failed I could hook up the esp device to usb and update that way.
I’ve managed to load firmware to a wemo d1, nodemcu and sonoff basic.
