Help: Everything Presence One
Hi, i’ve been struggling to set up my Everything Presence One. I feel like i might be missing something obvious. But i’m finding it hard to debug.
I’ve followed the set up guide, and have added the defult YAML code.
I’ve copied it below for refrence.
When i try and interact with the sensor, i dont get any of the options to configure any of the onboard sensors? Has anyone else come across this in the past?
substitutions:
  friendly_name: "Everything Presence One"
  project_name: "Everything Smart Technology.Everything Presence One"
  project_version: "1.1.7"
  temperature_offset: "-3"
  humidity_offset: "5"
  temperature_update_interval: "60s"
  illuminance_update_interval: "30s"
  hidden_ssid: "false"
  factory_reset_disabled: "true"
  uart_target_output_disabled: "true"
  uart_presence_output_disabled: "true"
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: true
  project:
    version: ${project_version}
esp32:
  board: esp32dev
logger:
  # default: warn
  logs:
    homeassistant.components.sensor.everything_presence_one: debug
api:
ota:
wifi:
  fast_connect: ${hidden_ssid}
  ap: {}
captive_portal:
improv_serial:
esp32_improv:
  authorizer: none
dashboard_import:
  package_import_url: github://everythingsmarthome/everything-presence-one/everything-presence-one.yaml@main
  import_full_config: false
light:
  - platform: status_led
    name: ESP32 status LED
    pin: GPIO32
    entity_category: config
    disabled_by_default: True
  - platform: binary
    restore_mode: RESTORE_DEFAULT_OFF
    output: mmwave_led_output
output:
    type: binary
    write_action:
      - switch.turn_off: mmwave_sensor
      - delay: 1s
      - if:
          condition:
            lambda: !lambda return state;
          then:
            - uart.write: "setLedMode 1 0"
          else:
            - uart.write: "setLedMode 1 1"
      - delay: 1s
      - uart.write: "saveConfig"
      - delay: 3s
      - switch.turn_on: mmwave_sensor
i2c:
  sda: 26
  scl: 25
  scan: true
  - platform: shtcx
    temperature:
      filters:
        - offset: ${temperature_offset}
        - lambda: "return x + id(temperature_offset_ui).state;"
    humidity:
      filters:
        - offset: ${humidity_offset}
        - lambda: "return x + id(humidity_offset_ui).state;"
    address: 0x70
    update_interval: ${temperature_update_interval}
  - platform: bh1750
    address: 0x23
    update_interval: ${illuminance_update_interval}
    filters:
      - lambda: "return x + id(illuminance_offset_ui).state;"
binary_sensor:
  - platform: gpio
    device_class: occupancy
    pin:
      number: GPIO15
      mode: INPUT_PULLDOWN
  - platform: gpio
    pin:
      number: 33
    device_class: motion
    filters:
      - delayed_off:  !lambda 'return id(pir_off_latency).state * 1000.0;'
    filters:
      - delayed_off: !lambda 'return id(occupancy_off_latency).state * 1000.0;'
    on_state:
      - lambda: 'id(illuminance_sensor).update();'
    lambda: |-
      if ( id(mmwave).state or id(pir_motion_sensor).state) {
        return true;
      else if (id(mmwave).state == 0 and id(pir_motion_sensor).state == 0) {
        return false;
      else {
        return id(occupancy).state;
uart:
  tx_pin: GPIO13
  rx_pin: GPIO14
  baud_rate: 115200
  debug:
    direction: BOTH
    dummy_receiver: true
    after:
      delimiter: "\n"
    sequence:
      - lambda: UARTDebug::log_string(direction, bytes);
switch:
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    turn_on_action:
      - uart.write: "sensorStart"
      - delay: 1s
    turn_off_action:
      - uart.write: "sensorStop"
      - delay: 1s
    name: UART presence output
    internal: ${uart_presence_output_disabled}
    optimistic: true
    turn_on_action:
      - delay: 1s
      - uart.write: "setUartOutput 1 1"
      - delay: 1s
      - delay: 3s
    turn_off_action:
      - delay: 1s
      - uart.write: "setUartOutput 1 0"
      - delay: 1s
      - delay: 3s
    name: UART target output
    internal: ${uart_target_output_disabled}
    optimistic: true
    assumed_state: false
    turn_on_action:
      - delay: 1s
      - uart.write: "setUartOutput 2 1 1 1"
      - delay: 1s
      - delay: 3s
    turn_off_action:
      - delay: 1s
      - uart.write: "setUartOutput 2 0"
      - delay: 1s
      - delay: 3s
number:
    icon: mdi:arrow-left-right
    min_value: 0
    max_value: 800
    initial_value: 315
    optimistic: true
    step: 15
    restore_value: true
    unit_of_measurement: cm
    mode: slider
    set_action:
      - delay: 1s
      - uart.write: !lambda int cm = (int)ceil(x / 15.0);
          std::string cms = "detRangeCfg -1 0 " + to_string(cm);
          return std::vector<unsigned char>(cms.begin(), cms.end());
      - delay: 1s
      - uart.write: "saveCfg 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
      - delay: 1s
    name: mmWave off latency
    icon: mdi:clock-end
    min_value: 1
    max_value: 600
    initial_value: 15
    optimistic: true
    step: 5
    restore_value: true
    unit_of_measurement: seconds
    mode: slider
    set_action:
      - delay: 1s
      - uart.write: !lambda |-
          std::string mss = "setLatency " + to_string(id(mmwave_on_latency).state) + " " + to_string(id(mmwave_off_latency).state);
          return std::vector<unsigned char>(mss.begin(), mss.end());
      - delay: 1s
      - delay: 1s
    name: mmWave on latency
    icon: mdi:clock-start
    min_value: 0
    max_value: 2
    initial_value: 0
    optimistic: true
    step: 0.25
    restore_value: true
    mode: slider
    set_action:
      - delay: 1s
      - delay: 1s
      - delay: 1s
    name: mmWave sensitivity
    icon: mdi:target-variant
    min_value: 0
    max_value: 9
    initial_value: 7
    optimistic: true
    step: 1
    restore_value: true
    set_action:
      - delay: 1s
      - uart.write:
          !lambda std::string mss = "setSensitivity " + to_string((int)x);
      - delay: 1s
      - delay: 1s
    name: Occupancy off latency
    icon: mdi:clock-end
    min_value: 1
    max_value: 600
    initial_value: 15
    optimistic: true
    step: 5
    restore_value: true
    mode: slider
    name: PIR off latency
    icon: mdi:clock-end
    min_value: 1
    max_value: 120
    initial_value: 10
    optimistic: true
    step: 1
    restore_value: true
    mode: slider
    unit_of_measurement: "°C"
    min_value: -20
    max_value: 20
    step: 0.1
    mode: box
    update_interval: never
    optimistic: true
    restore_value: true
    initial_value: 0
    icon: "mdi:thermometer"
    on_value:
      - lambda: 'id(shtc3_sensor).update();'
    unit_of_measurement: "%"
    min_value: -50
    max_value: 50
    step: 0.1
    mode: box
    optimistic: true
    restore_value: true
    initial_value: 0
    icon: "mdi:water-percent"
    on_value:
    unit_of_measurement: "lx"
    min_value: -50
    max_value: 50
    step: 1
    mode: box
    optimistic: true
    restore_value: true
    initial_value: 0
    icon: "mdi:brightness-5"
    on_value:
button:
  - platform: restart
    internal: true
    name: Restart mmWave sensor
    internal: true
    on_press:
      - uart.write: "resetSystem"
    icon: mdi:restart
    on_press:
      - button.press: restart_mmwave
      - button.press: restart_internal
  - platform: safe_mode
    internal: false
    name: Factory reset mmWave
    icon: mdi:cog-counterclockwise
    internal: ${factory_reset_disabled}
    on_press:
      - delay: 1s
      - uart.write: "resetCfg"
      - delay: 3s
They have their own Discord and a dedicated section for the EP1 - they can almost certainly better help you.
