Seeing this also.
I have a zigbee relay that is based outdoors. It’s within good range of several routers but appears to work at random. It’s quite annoying as it controls the outdoor lighting, or at least it is supposed to!
Did anyone find a solution to this?
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:226
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 26 October 2023 at 16:34:32 (25 occurrences)
Last logged: 20:06:02
[546647998656] Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
[546201818432] Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
[546459849920] Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
[546354337984] Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
[546737141312] Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 64, in wrap_zigpy_exceptions
yield
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 84, in wrapper
return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/zigpy/util.py", line 132, in retry
return await func()
File "/usr/local/lib/python3.11/site-packages/zigpy/quirks/__init__.py", line 199, in command
return await self.request(
File "/usr/local/lib/python3.11/site-packages/zigpy/zcl/__init__.py", line 377, in request
return await self._endpoint.request(
File "/usr/local/lib/python3.11/site-packages/zigpy/endpoint.py", line 253, in request
return await self.device.request(
File "/usr/local/lib/python3.11/site-packages/zigpy/device.py", line 293, in request
await self._application.request(
File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 828, in request
await self.send_packet(
File "/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py", line 870, in send_packet
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 226, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2012, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2049, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 235, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 876, in entity_service_call
response_data = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 948, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 591, in async_handle_light_off_service
await light.async_turn_off(**filter_turn_off_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/zha/light.py", line 471, in async_turn_off
result = await self._on_off_cluster_handler.off()
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 83, in wrapper
with wrap_zigpy_exceptions():
File "/usr/local/lib/python3.11/contextlib.py", line 155, in __exit__
self.gen.throw(typ, value, traceback)
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 75, in wrap_zigpy_exceptions
raise HomeAssistantError(message) from exc
homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
