I’ve tried to create a new hass-addon the last few days, and have the program itself working. It’s a server built in rust that talks to something called an enet gateway and posts to MQTT (so that hopefully I can controll the lights in HA). I was quite excited to get this to work, but I have stumbled on the last part of the journey which is getting the docker image working. I’ve managed to get the repository set up, and installed the image into a HASS instance I have, but it just dies pretty immediately, and I can’t figure out why. I’m using the home-assistant ubuntu 18:04 base image (the server I’m trying to run expect glibc), which includes the s6-overlay (which I have no experience with), so I tried to copy what other addons do and create a /etc/services.d/enet-mqtt/run
script, but it doesn’t seem to ever be invoked.
To debug further, I added a bunch of log statements to the run script (which now looks like this):
#!/usr/bin/with-contenv bashio
# Start enet service
bashio::log.info "enet/run..."
ENET_GATEWAY=$(bashio::config 'gateway')
bashio::log.info "enet/run 1..."
MQTT_PASSWORD="$(bashio::jq /data/auth.json '.enet_password')"
bashio::log.info "enet/run 2..."
# Wait until mosqitto is up and running
bashio::log.info "Starting enet-mqtt..."
bashio::net.wait_for 1883
bashio::log.info "enet/run 3..."
export ENET_MQTT_PASS="${MQTT_PASSWORD}"
# Run daemon
bashio::log.info "enet/run 4..."
exec /usr/bin/enet-mqtt \
--gateway "${ENET_GATEWAY}" \
--mqtt-host 127.0.0.1 \
--mqtt-port 1883 \
--mqtt-user "enet"
However, I see none of this in my logs:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[cmd] /bin/bash exited 0
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
The docker image and the code used to build all of this is available here: hass-addons/enet at main · YoloDev/hass-addons · GitHub. I’m kind of at a loss of how to proceed here, so any help would be much appreciated.
