Hi guy’s, new to the Home Assistant eco system after tarting off with Alexa and app’s to control my home. Decided to take the leap into Home Assistand and trying to get my first automation to work.
Trying to get my Living Room door sensor to switch on my Conservatory lights after dark. Can anyone see any mistake I have made as when I check my dashboard, all show as open but no lights come on.
Light switch is plug through Tuya and door sensor is Zigbee through ConBee 2
In the future, please share text instead of pictures of text. The problem is that your condition will never be true because including both before: and after: with the sun platform requires both to be true. That’s impossible, and is mentioned in the docs here. You can either split it into two conditions, or use something like sun.sun elevation or below_horizon/above_horizon. The latter two options are generally superior to sunrise/sunset anyway.
Thanks for the info. went back and changed condition and read the docs you said about.
alias: Conservatory Lights On
description: Turn on conservatory lights when Living Room door is opened after dark
and if not on.
platform: state
entity_id: binary_sensor.tz3000_6jeesvrt_ts0203_ias_zone
to: ‘on’
condition:
condition: state
entity_id: sun.sun
state: below_horizon
I don’t think your automation implements the last thing mentioned in the description: and if not on.
When the door is opened and the sun is below_horizon, the automation will always execute switch.turn_on even if the switch is already on.
If you want the automation to work precisely like it describes its operation in its description, simply add a second State Condition that checks if the switch is currently off.
description: Turn on conservatory lights when Living Room door is opened after dark and if not on.
- platform: state
to: 'on'
condition:
- condition: state
entity_id: sun.sun
- condition: state
entity_id: switch.72627180bcddc2926884
state: 'off'
- service: switch.turn_on
mode: restart
