I have recently updated to the new nest thermostat integration. The logs are now haunting me about Badnest. I removed the yaml portion I added but I cant remove the integration from HACS because the files are removed from github. I went to HACS and tried uninstall. No luck. What can I do without breaking more things?
Anyone have an idea?
I think HACS only added the file for Badnest Integration
into your custom_component
in your /config
folder.
Can you try to back it up and then remove it from custom_component
Maybe, I will have to try that.
Step 1: Delete it from HACS
Step 2: Remove it from custom_component if the file is still there
