Hi i really really need help integrating cozytouch and automation. The bridge is connected to the thermostat of the Atlantic heat pump, air water heat pump atlantic alfea extensa duo
I integrated the application without problem in home assistant
I don’t see the cozytouch integration in home assiatant https://www.home-assistant.io/integrations#search/cozy
It IS in hacs
Thank you, that helped me find it. I wonder if you might be better posting on github issues? The author is sure to see it there.
Ok thanks, where could i post ma question ? M
