Hi everyone,
I’m new with HA and i want to use a DFPlayer with a esp32-C3.
But, when i try to build my code, i have an error for just one APIservice to remote the DFPlayer :
- service: dfplayer_play
variables:
file: int
then:
- dfplayer.play: !lambda 'return file;'
And my error is :
FO Reading configuration /config/esphome/wemos-pico.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing wemos-pico (board: esp32-c3-devkitm-1; framework: espidf; platform: platformio/espressif32 @ 3.3.2)
HARDWARE: ESP32C3 160MHz, 320KB RAM, 4MB Flash
- framework-espidf @ 3.40302.0 (4.3.2)
- tool-cmake @ 3.16.9
- tool-ninja @ 1.10.2
Reading CMake configuration...
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- noise-c @ 0.1.4
| |-- libsodium @ 1.10018.1
Compiling /data/wemos-pico/.pioenvs/wemos-pico/src/main.o
Linking /data/wemos-pico/.pioenvs/wemos-pico/firmware.elf
/data/cache/platformio/packages/toolchain-riscv-esp/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld: /data/wemos-pico/.pioenvs/wemos-pico/src/main.o: in function `void esphome::api::UserServiceBase<long>::execute_<0>(std::vector<esphome::api::ExecuteServiceArgument, std::allocator<esphome::api::ExecuteServiceArgument> >, esphome::seq<0>)':
/config/esphome/.esphome/build/wemos-pico/src/esphome/components/api/user_services.h:56: undefined reference to `long esphome::api::get_execute_arg_value<long>(esphome::api::ExecuteServiceArgument const&)'
/data/cache/platformio/packages/toolchain-riscv-esp/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld: /data/wemos-pico/.pioenvs/wemos-pico/src/main.o: in function `esphome::api::ListEntitiesServicesArgument::ListEntitiesServicesArgument()':
/config/esphome/.esphome/build/wemos-pico/src/esphome/components/api/api_pb2.h:796: undefined reference to `esphome::api::enums::ServiceArgType esphome::api::to_service_arg_type<long>()'
collect2: error: ld returned 1 exit status
*** [/data/wemos-pico/.pioenvs/wemos-pico/firmware.elf] Error 1
========================= [FAILED] Took 136.18 seconds =========================
So, because of that, i can’t try my DFPlayer with HA (the others APIservices seems ok but i can’t play a song with these services in my YAML)
Here my YAML (build ok) :
esphome:
platformio_options:
board_build.flash_mode: dio
esp32:
framework:
type: esp-idf
platform_version: 3.3.2
sdkconfig_options:
CONFIG_BT_BLE_42_FEATURES_SUPPORTED: y
uart:
tx_pin: GPIO4
rx_pin: GPIO5
baud_rate: 9600
dfplayer:
on_finished_playback:
then:
logger.log: 'Somebody press play!'
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "DxBtcVUodE+AsnZ226eVS5jI6n2ZbHJAsxLNWJjeFFc="
services:
- service: dfplayer_next
then:
- dfplayer.play_next:
- service: dfplayer_previous
then:
- dfplayer.play_previous:
- service: dfplayer_start
then:
- dfplayer.start
variables:
file: int
then:
ota:
password: "2c77524645aaea56d8e697bdd02016e7"
wifi:
power_save_mode: LIGHT
fast_connect: true
ssid: "Redmi Note 8 Pro"
password: "***************"
ap:
ssid: "Esp-32 Fallback Hotspot"
password: "umo1p893gwhd"
esp32_ble_tracker:
- platform: adc
pin: GPIO3
accuracy_decimals: 2
update_interval: 2s
attenuation: 11dB
filters:
- multiply: 2.0 # The voltage divider requires us to multiply by 2
# RSSI based on MAC address
- platform: ble_rssi
mac_address: ****************
name: "SmartWatch RSSI value"
I tried to clean the build files and create a new composant but both failed.
Anyone an idea ?
(Sorry for my bad english :D)
Tkank’s
