Hi, I’m italian, I need a tutorial for flashing a Sonoff Touch wall switch with a firmware MQTT compatible to use with HA.
I saw many info about but some of them use ESPEasy, some Tasmota and other firmwares.
I’m a newbie, I need the simplest solution… and a tutorial step by step to do it.
Read through the Tasmota wiki, which you seem to have already found, and it will give you what you’re after, tutorials, link to vids, differences between devices and the necessary set up differences.
Platformio is the simplest method as recommended on that site.
sorry… I’m unable to find wich is the GPIO_0 on the new PSF-A chip… I have to link it to GND of FTDI
PSF-A chip of new Sonoff Touch has different design
Board layout seems the same as the left hand image in the wiki and it does say the position of gpio0 is the same whichever chip you have so that’s what I’d go for.
after I restart switch board
Then I go to Serial monitor… choosed USB serial port COM8 … and 115000 baud …clic START
but it write a infinite string of special characters
Have you tried just powering it up and going to it’s web interface? The important bit is the success message and you got that. I flashed 10 Basics at the weekend and didn’t bother with the serial monitor bit, didn’t see the point.
