I have been using HA on and off for a while now, but am now getting serious with a fresh start and more involved settup.
I have just tried to reboot the system but am getting the following error
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Error loading /config/configuration.yaml: expected ‘’, but found ‘’ in “/config/configuration.yaml”, line 6, column 1
de
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
