Help for newbie
I run several devices with tasmota but wanted to give a try to esphome so I used by (poor) knowedge to try to migrate one shelly 1 and one sonoff basic to ESPHOME.
The problem is that I think I’m at a dead end.
Let me explain.
The Shelly 1 is regularly connecte to my network. It is “online” in esphome dashboard. But I cannot connect to it and it does not appear in Home Assistant integration. Below the log:
INFO Reading configuration /config/esphome/telecamera-balcone.yaml...
INFO Starting log output from telecamera-balcone.local using esphome API
WARNING Can't connect to ESPHome API for telecamera-balcone.local: Error connecting to ('192.168.2.160', 6053): [Errno 111] Connect call failed ('192.168.2.160', 6053)
INFO Trying to reconnect to telecamera-balcone.local in the background
The Sonoff Basic appears offline now but some hour ago was online in my network and “online” also in the esphome dashboard. :dizzy_face:
Any suggestion?
