Help generating ssh keys so I can run an ssh command from home-assistant in docker
Hi my setup is as follows
ubuntu server 18.04 lts
homeassistant running in docker
I want to run this command wakeonlan xx:xx:xx:xx:xx on the server via ssh from inside the home assistant docker container.
I’m confused how to do it. I was looking at this guide here:
I know how to access a terminal inside the homeassistant container as root.
I’m confused about where I make they keys and do I need private or public keys.
Can anyone guide me what to do.
Actually that all works fine. I don’t need help. If anyone finds this thread and is stuck.
run a terminal under the home assistant docker as root
  • you can use portainer, click on the container, then choose to open a console
  • or you can type docker exec -it homeassistant bash on your server
Then go through all the commands in the guide.
Here is a wakeonlan switch for those in docker
