Hey guys,
I’m trying to get a tuya device working with localtuya and currently running 107 in VM.
I’ve copied over the localtuya directory from @mileperhour and now have
config
custom_components
localtuya
switch.py
manifest.json
init.py
pytuyainit.py
I updated the switch.py code to have from . import pytuya
I’ve confirmed that the device ID, Local Key and IP address are all correct and working using TuyaCLI, where I’m able to successfully tun on the device.
But I’m still getting an error in the Developer Tools Logs
Log Details (ERROR)
Logger: homeassistant.components.switch
Source: custom_components/localtuya/switch.py:97
Integration: Switch (documentation, issues)
First occurred: 9:48:01 AM (1 occurrences)
Last logged: 9:48:01 AM
Error while setting up localtuya platform for switch
File "/config/custom_components/localtuya/switch.py", line 93, in __get_status
status = self._device.status()
File "/config/custom_components/localtuya/pytuya/__init__.py", line 259, in status
data = self._send_receive(payload)
File "/config/custom_components/localtuya/pytuya/__init__.py", line 171, in _send_receive
data = s.recv(1024)
ConnectionResetError: [Errno 104] Connection reset by peer
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 179, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/config/custom_components/localtuya/switch.py", line 74, in setup_platform
config.get(CONF_ID)
File "/config/custom_components/localtuya/switch.py", line 127, in __init__
self._status = self._device.status()
File "/config/custom_components/localtuya/switch.py", line 111, in status
self._cached_status = self.__get_status()
File "/config/custom_components/localtuya/switch.py", line 97, in __get_status
raise ConnectionError("Failed to update status.")
ConnectionError: Failed to update status.
Any ideas what this could be? How I might be able to fix it?
I have the following setup as a package for my config
# RecTec RT-700 Bull Package
# Climate
# Sensors
sensors:
rectec_target:
value_template: >-
{{ states.switch.rectec.attributes.target }}
unit_of_measurement: 'F'
rectec_current:
value_template: >-
{{ states.switch.rectec.attributes.current }}
rectec_probea:
value_template: >-
{{ states.switch.rectec.attributes.probea }}
rectec_probeb:
value_template: >-
{{ states.switch.rectec.attributes.probeb }}
# switch
switch:
- platform: localtuya
host: !secret rectec_host
local_key: !secret rectec_local_key
device_id: !secret rectec_device_id
