Help getting started with automation scripts
Hello everybody,
I’m very new to Home Assitant - coming from Domoticz.
I used to configure all my automation on Domoticz using blocky wich was very easy and user-friendy and i’m having a hard time to understand how to migrate my automations.
I did have read the doc on automation but still do not understand how to reach my goal :frowning:
If my understanding is good, i’ll have to deal with scritps: every automation that i want will be placed in a file called script.yaml.
What i’m trying to get is something like this but i dont understand how to deal with the if / or / else.
What this exemple would looks like transposed in yaml?
Sorry if it may sounds idiot :slight_smile:
Looking forward for your help!
Regards - JS
No this is not true. Scripts and automations are different.
Automations - triggered by something, (with optional conditions), they then perform a list of actions.
Scripts - perform a list of actions (with optional conditions). No trigger for scripts. They can be called manually or as an action (service) from an automation.
There is also now a device oriented graphical automation editor. Select one of your devices from the Configuration / Devices menu, then:
Thanks for your clarifications about the differences between the automations and script
So, in order to achieve what i want, i need a combination of both.
Every automation that i create should call a different script.
What would the script looks like with the example in the first post?
Automations contain a list of actions. No need for a script, unless you are repeating the same list of actions in different automations. Then you could use a script to reduce duplication.
automation:
- alias: automation1
  - platform: some_platform
  conditon: [] # optional
   - service: blah
   - service: blah
   - service: blah
- alias: automation2
  condition: [] # optional
   - service: blah
   - service: blah
   - service: blah
   - service:  something_else
or
automation:
  - script.blah
automation:
  - script.blah
script:
  sequence:
  - service: blah
  - service: blah
  - service: blah
Thanks for your answer, but i still dont get how it works as “blah” is a bit generic :slight_smile: and, for exemple, how the condition for time is set in your demonstration?
It looks very clear for you but for me it still looks like black magic xD
Well I was trying not to confuse you with all the services available. Read the docs for the services you want to call, for example to switch a light on:
  - service: light.turn_on
    entity_id: light.your_light
Time condition: https://www.home-assistant.io/docs/scripts/conditions/#time-condition
Thanks for your time and help!
Really appreciate
You will also find this useful for the types of automation triggers available:
