So, I’m already tired of the HassOS hardening of the OS that I want to move from HassOS to Rasbian Docker. So I installed Rasbian Buster Lite, Docker and Hassio on the Raspberrypie 4 that I normally use for OctoPrint. Started fine, got the Home Assistant web page which I created an account to get it going. I then promptly shut it down, as well as my real Raspberrypie running my live HassOS.
From there, I copied the HassOS /config directory to the /usr/share/hassio/homeassistant/ on Raspbian, minus the home-assistant_v2.db because it’s 400 MB and I think it only records events anyway.
When I started up the Rasbian Hassio again (docker start raspberrypi4-homeassistant), what I got wasn’t what I expected. Missing lots of devices and my UI was actually the debug page and not my Lovelace UI. I shut it down, moved the SD card to the original Raspberrypi (to get the original IP address that my switches talks to through auto discovery MQTT) but had the exact same result
Are there steps I missed to move my config from one system to another (and keeping the IP address)?
Thanks.
