Help/Guidance Needed with an error
So, I keep getting the following errors in my “home-assistant.log” file. The error after the #######, keeps repeating, with only the last line that changes.
I have an Automation that restarts HASSIO, every night at 2:00am,
2018-07-20 02:01:05 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-07-20 02:01:35 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-07-20 02:48:20 ERROR (SyncWorker_12) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 08:00:03 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
  File "uvloop/sslproto.pyx", line 593, in uvloop.loop.SSLProtocol._on_handshake_complete
  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:841)
2018-07-20 08:00:03 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: UNKNOWN_PROTOCOL
  File "uvloop/sslproto.pyx", line 497, in uvloop.loop.SSLProtocol.data_received
  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
------------------------------The following line, is the ONLY line that changes------------------------------------
2018-07-20 08:01:33 ERROR (SyncWorker_5) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
Below is the ERRORs that show up in the last line of the above error. (Each error is separated by “#######”)
2018-07-20 08:48:31 ERROR (Dummy-413) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 09:14:37 ERROR (zeroconf-Engine) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 10:01:35 ERROR (zeroconf-Engine) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 10:12:02 ERROR (SyncWorker_14) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 10:38:10 ERROR (SyncWorker_7) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 11:14:42 ERROR (SyncWorker_0) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 11:46:03 ERROR (Dummy-592) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 11:51:16 ERROR (SyncWorker_12) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 12:59:10 ERROR (zeroconf-Engine) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 13:35:42 ERROR (SyncWorker_0) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 13:40:55 ERROR (SyncWorker_9) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 14:17:28 ERROR (SyncWorker_16) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 15:25:00 ERROR (Recorder) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 16:01:54 ERROR (zeroconf-Engine) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 16:07:07 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 16:12:20 ERROR (SyncWorker_12) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 16:48:52 ERROR (SyncWorker_13) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 17:20:11 ERROR (zeroconf-Engine) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 17:56:44 ERROR (zeroconf-Engine) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 18:22:49 ERROR (SyncWorker_12) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 18:43:41 ERROR (SyncWorker_9) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 19:07:41 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 19:51:34 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-20 20:22:03 ERROR (Recorder) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
Notice that there are 3 errors that had 2 lines at the end, and 2 errors that had NO last line, (denoted by the DOUBLE rows of “#######”).
My Setup is as follows.
SETUP - Raspberry Pi 3B running Latest version of HASSIO w/ 32Gb SD
ADD-ONs - Configurator, Dashio, Duck DNS, Mosquitto, Node-Red, SSH - Secure Shell, Samba, TasmoAdmin
INSTALLED HARDWARE - Nortek Z-Wave/Zigbee USB Stick
Connected to Network by EtherNet cable.
I’m facing the exact same issue.
New Info:
This error goes away, if I disable “443 to 8123” port forwarding. But when I do, I lose the “Certificate Expiry” sensor.
