Help HA broken
Hello friends, I need your help. HA constantly falls back to an old save after restarting and everything I changed from the save up to that point in the dashboard or added integrations are gone after the restart. The SSD is new and has 265GB of storage. HA runs on a Mini PC with 265GB memory and 16GB Ram with HAOS
Anything in the logs?
It doesn’t say anything there as to what could be the problem
If there is nothing in the logs, It sounds like your file system may be in read-only mode. This can happen if the disk is full or the file system is corrupt. You may want to take a backup, reformat the disk or use a new disk, reinstall Home Assistant, then restore the backup.
I have already done all of that. I bought a new SSD with 256 GB storage and loaded it onto the new SSD via backup but the problem is still there
Settings → System → Repairs
Click on the three dots in the upper right corner and click on System Information
Provide a copy of that information here.
System Information
version core-2024.12.4
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.13.0
os_name Linux
os_version 6.6.66-haos
arch x86_64
timezone Europe/Berlin
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
HACS Data ok
GitHub API Calls Remaining 5000
Installed Version 2.0.1
Stage running
Available Repositories 1508
Downloaded Repositories 90
Home Assistant Cloud
logged_in true
subscription_expiration 14. August 2025 um 02:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
alexa_enabled false
google_enabled false
cloud_ice_servers_enabled true
remote_server eu-central-1-17.ui.nabu.casa
certificate_status ready
instance_id 11dcb4763a3a418e9186c539d98b6d4a
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 14.1
update_channel stable
supervisor_version supervisor-2024.12.0
agent_version 1.6.0
docker_version 27.2.0
disk_total 3666.9 GB
disk_used 10.6 GB
healthy true
supported true
host_connectivity true
supervisor_connectivity true
ntp_synchronized true
virtualization
board generic-x86-64
supervisor_api ok
version_api ok
installed_addons Advanced SSH & Web Terminal (19.0.0), File editor (5.8.0), Spotify Connect (0.13.0), Govee to MQTT Bridge (2024.07.13-82ddc6e9), Mosquitto broker (6.4.1), PS5 MQTT (1.4.0), Home Assistant Google Drive Backup (0.112.1), AirCast (4.2.3), Music Assistant Server (2.3.3), Silicon Labs Multiprotocol (2.4.5), ESPHome Device Builder (2024.12.1), Matter Server (6.6.1), Zigbee2MQTT (1.42.0-2)
Dashboards
dashboards 6
resources 68
views 50
mode storage
Recorder
oldest_recorder_run 7. Dezember 2024 um 11:52
current_recorder_run 20. Dezember 2024 um 02:00
estimated_db_size 203.01 MiB
database_engine sqlite
database_version 3.45.3
Spotify
api_endpoint_reachable ok
Just to confirm, did this problem exist before using the new SSD?
Have you examined each of these files?
  • Home-assistant.log
  • home-assistant.log.1
  • Home-assistant.log.fault
Yes, the problem was already before the new SSD. I used a new SSD because I assumed that my old SSD might
is defective. There is nothing in the log files that would explain this, only that some integrations are out of date, but it is not the integrations that are causing problems
I noticed you have 6 dashboards. Is the problem occurring on all 6 dashboards?
yes because after the restart HA deletes all added integrations, changes in the dashboard, calendar etc. that I have added or changed since the save. I have to add and change everything manually after each restart
Is your system booting into Recovery Mode?
No the system does not start in safe mode. it starts in normal mode
Recovery mode is different than safe mode. I asked because recovery mode typically exhibits the type of behavior you are describing: “it will still continue to start using parts of the configuration from the last time Home Assistant did start.”
Can I somehow find out if it starts in this mode?
There should be a notification at the top of the page.
Have you updated all your HACS integrations, rebooted your host computer, then checked to see if the issue persists?
