Found some information. These are my results, but I don’t have a clue if this is indicating a problem:
martctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.0-58-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model: ADATA SP550NS38
Serial Number: 2G4220001161
Firmware Version: P0414B
User Capacity: 120,034,123,776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
TRIM Command: Available, deterministic, zeroed
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Feb 8 09:08:42 2023 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x02) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 171) seconds.
capabilities: (0x71) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 2) minutes.
Conveyance self-test routine
SCT capabilities: (0x0035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x0000 100 100 000 Old_age Offline - 0
5 Reallocated_Sector_Ct 0x0000 100 100 000 Old_age Offline - 0
9 Power_On_Hours 0x0000 100 100 000 Old_age Offline - 13623
12 Power_Cycle_Count 0x0000 100 100 000 Old_age Offline - 67
160 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 0
161 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 114
163 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 10
164 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 167326
165 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 161
166 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 61
167 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 127
168 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 1000
169 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 88
175 Program_Fail_Count_Chip 0x0000 100 100 000 Old_age Offline - 0
176 Erase_Fail_Count_Chip 0x0000 100 100 000 Old_age Offline - 0
177 Wear_Leveling_Count 0x0000 100 100 050 Old_age Offline - 671
178 Used_Rsvd_Blk_Cnt_Chip 0x0000 100 100 000 Old_age Offline - 0
181 Program_Fail_Cnt_Total 0x0000 100 100 000 Old_age Offline - 0
182 Erase_Fail_Count_Total 0x0000 100 100 000 Old_age Offline - 0
192 Power-Off_Retract_Count 0x0000 100 100 000 Old_age Offline - 13
194 Temperature_Celsius 0x0000 100 100 000 Old_age Offline - 35
195 Hardware_ECC_Recovered 0x0000 100 100 000 Old_age Offline - 0
196 Reallocated_Event_Count 0x0000 100 100 016 Old_age Offline - 0
197 Current_Pending_Sector 0x0000 100 100 000 Old_age Offline - 0
198 Offline_Uncorrectable 0x0000 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0000 100 100 050 Old_age Offline - 0
232 Available_Reservd_Space 0x0000 100 100 000 Old_age Offline - 100
241 Total_LBAs_Written 0x0000 100 100 000 Old_age Offline - 808106
242 Total_LBAs_Read 0x0000 100 100 000 Old_age Offline - 76839
245 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 334652
SMART Error Log Version: 1
Warning: ATA error count 0 inconsistent with error log pointer 1
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 0 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
When the command that caused the error occurred, the device was in an unknown state.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
00 ec 00 00 00 00 00 Device Fault
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 00 00 00 00 00 00 00:00:00.000 READ DMA
Warning! SMART Self-Test Log Structure error: invalid SMART checksum.
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 55 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
7 0 65535 Read_scanning was completed without error
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
