I’ve just tried to move from 2022.6.6 to 2002.7.6 but the boot process hangs starting raspberry integration
This is the message:
2022-07-23 18:28:02 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
I run over pi3
I’ve got also a lot of other errors that seems related to pyton
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [15 lines of output]
running bdist_wheel
running build
running build_py
Compiling ws281x library…
creating build
creating build/lib.linux-aarch64-cpython-310
creating build/lib.linux-aarch64-cpython-310/rpi_ws281x
copying rpi_ws281x/rpi_ws281x.py → build/lib.linux-aarch64-cpython-310/rpi_ws281x
copying rpi_ws281x/init.py → build/lib.linux-aarch64-cpython-310/rpi_ws281x
running build_ext
building ‘_rpi_ws281x’ extension
creating build/temp.linux-aarch64-cpython-310
creating build/temp.linux-aarch64-cpython-310/lib
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I. -I/usr/local/include/python3.10 -c lib/dma.c -o build/temp.linux-aarch64-cpython-310/lib/dma.o
error: command ‘gcc’ failed: No such file or directory
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for rpi_ws281x
error: subprocess-exited-with-error
│ exit code: 1
* Setup can’t determine the value of PAGE_SIZE on your system, so it will
* default to 4096 which may not be correct.
* Please report this message and your operating system info to the package
* maintainer listed in the README file.
running bdist_wheel
running build
running build_ext
building ‘sysv_ipc’ extension
creating build
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/local/include/python3.10 -c common.c -o build/temp.linux-aarch64-cpython-310/common.o
[end of output]
ERROR: Failed building wheel for sysv_ipc
Hi !
I have the same problem . Waiting on integrations to complete setup: raspberry pi
did you find a solution?
