Help. Yesterday HAOs server just crashed. Today I got up in the same way, but I have such a bed sheet in my logs
2023-07-28 17:15:35.962 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration fontawesome which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-07-28 17:15:35.965 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_miot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-07-28 17:15:35.967 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hikvision_next which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-07-28 17:15:35.970 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-07-28 17:15:35.973 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-07-28 17:15:35.975 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration rhvoice which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-07-28 17:15:35.977 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration gree which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-07-28 17:15:35.980 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration mega which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-07-28 17:15:35.982 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration thermal_comfort which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant```
