ysinata
(YSinata)
July 2, 2018, 5:48am
1
help pls…
i’ve read everything (i think) regarding this, and so far i have not been able to access my duckdns URL.
Currently my setup is:
RB PI 3B+
Running HASSBIAN (Updated to the latest version) installed following homeassistant.io guide for hassbian
Setup static IP for my pi
Port forward 443>8123 on both protocol
Reboot my router
Duck DNS set up following this:
github.com/home-assistant/hassbian-scripts/blob/dev/docs/duckdns.md
here is my yaml file config:
Now i can access my HA from
https://hassbian.local:8123
but
https://mydomain.duckdns.org
doesnt work…
any idea?
thanks in advance
tom_l
July 2, 2018, 6:03am
2
Have you put the following in your configuration.yaml file:
http:
base_url: https://my-domain.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Does the DuckDNS.org site list your correct public IP address?
ysinata
(YSinata)
July 2, 2018, 3:12pm
3
i did have ssl_cert in my config yaml file, but the one u share is very short. the one i got is much longer. can u check my attached image?
and yes Duck DNS IP is correct. I can ping it and the result is correct.
You’ve said your base url is https://mydomain.duckdns.org:8123 so that is what you should be trying to access it from and you need to forward 8123 to 8123.
If you set your base url as https://mydomain.duckdns.org without the port number and forward 443 to 8123 you can access it from https://mydomain.duckdns.org .
ysinata
(YSinata)
July 9, 2018, 9:21am
5
Hi there, sorry for the late reply, i have been busy with moving.
Anyway, i tried that, it still says secure connections failed… any idea?
thanks!
