I’ve been trying to solve a problem for a few weeks now without getting anywhere. My automations are not firing, I can trigger them manually through dev tools or in config > automations and then “Run Actions”.
I’ve tried a lot of solutions from the forums, but nothing has worked for me so far. Any ideas? Here is one of my simple automations that doesn’t work:
### Home Assistant Auto Restart
- id: "1630230394699"
alias: Home Assistant Auto Restart
description: ""
- platform: time
at: 05:00:00
condition:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
- service: homeassistant.restart
mode: restart
Ah, there we go, edited so you can see the code easier. Thank you for quick answers! I have other automations too, but it’s just the same things more or less just more complicated. This is also one of them:
### Turn oven on when temp is 20 C
- id: "1634499709931"
alias: Turn oven on when temp is 20 C
description: ""
- type: temperature
platform: device
device_id: 84c2c28ef648978d46f0c6a6924a03ff
entity_id: sensor.lumi_lumi_weather_temperature
domain: sensor
below: 20
for:
hours: 0
minutes: 0
seconds: 0
milliseconds: 0
condition: []
- type: turn_on
device_id: b8784ad818911c85494b39aab50b2dbc
entity_id: switch.smart_metering_plug
domain: switch
- delay:
hours: 0
minutes: 30
seconds: 0
milliseconds: 0
- type: turn_off
domain: switch
mode: restart
No need for the time condition, I just did this using HA creator in automation config, not in yaml. Therefore there are some extra code that is not needed, but it shouldn’t stay in the way for the automation to run.
I would love to get some more inputs on this, I’ve seen many others have the same problem as me. Not sure how they fixed it but I can’t find anyone similar to my situation that has solved the issue.
There is nothing about automations or anything in error logs that could be related to it. The automations have never been fired without me manually doing it. It means that they can fire, but they never do. So I know they work from doing it manually. It’s like it never does automations.
When you execute Run Actions, or the automation.trigger service call, all it does is run the automation’s action. It doesn’t exercise the automation’s trigger so it isn’t validating its functionality. For more information, refer to: Testing your automation.
True, I have been following all the steps on YouTube and forums for trying to get this to work. Been looking at the Troubleshooting guides as well. Still nothing. And when the trigger is as simple as a time of day but it still doesn’t trigger there must be something wrong another place and not the automation itself?
Correct. That’s why I suggested you check the log.
Here’s one possibility:
If you have a syntax error in one of your automations, that you edited with a text editor (not the Automation Editor), and then restarted Home Assistant, on startup it will refuse to load the Automations integration. The result of that is none of your automations will be triggered normally.
Automations created/edited with the Automation Editor will refuse to be saved if they contain a syntax error. Automations created with a text editor should be validated with Check Configuration. Theoretically, Home Assistant will refuse to restart if it detects a problem with its configuration (which includes defective automations) but a system reboot easily thwarts that safeguard.
Ok, I’ll look into the device_id as well as the syntax error. I have some other automations that I can get rid off. Maybe it will fix it. I’ll update on the progress.
Because your automations aren’t using Device-oriented Triggers, Conditions and Actions (which are the default offered when creating an automation with the Automation Editor). However, that’s immaterial to this problem.
Sorry if this is obvious, but “restart” is used to restart the automation if it is triggered a second time when it is already running. Normally you would use “single”, which is the default. If you do that, it will simply not run if it is triggered a second time when it is already running, and you’ll get a message in the log.
If it is not already running, an automation will always run when the trigger fires - you don’t need to restart it.
Again, sorry if this is obvious, but a trigger is an event, not a state. Your second automation should fire when the temperature crosses from 20C to 19C - it will not fire again until the temperature rises above 20C and drops again.
