Hello everyone,
I have been running HA on PI4 2GB for couple of months with RT-SDR 433Mhz and Zigbee Sonoff USB sticks and sonoff/sengled/tuya/aqara/433mhz switches/sensors. So far, I managed to make it work.
Now I need to setup another HA with a similar number of sensors with the addition of 2-3 HD/4K PoE surveillance cameras and the ability:
- See livestreams from cameras on HA dashboard, no need to record livestream locally
- Ability to detect objects and faces from the lifestream
- Ability to record the stream upon detection of motion/object/face/person - recording should stop once object/motion is not there anymore
- Get notified from HA regarding motion/object/person detection and have the ability to stream/download these files.
I currently have:
- An unused Nvidia Jetson Nano A01 - with 4GB of RAM and 128 cuda cores.
- Sandisk 256GB USB3 SSD
- Samsung 64GB Class2 high-performance SD-card
I don’t yet have PoE cameras and the second set of Zigbee/433Mhz sticks and sensors.
What I want to understand - how can I accomplish what I wrote i above?
Can all the above be accomplished by a single device both for running HA and doing GPU-accelerated video stream processing with low latency? If yes, can this be accomplished by my existing Jetson Nano? If yes - how and in which order?
If not, why? If Jetson Nano can’t be used as a ‘single device rule them on’ can at least I use it for video stream-related tasks? If yes, how do I integrate that part with HA which I probably need another device to run on?
I am sure someone tried to have a similar setup - if you have been successful, could you please write your experience of how you did it?
Thank you
