I manually installed home-assistant on raspberry pi long time ago by following this instruction below :
Lately I understand there is hass.io which kind like hass repository
So I add "hassio: " in configuration.yaml however i got error below
What I am missing?
IMO the installation docs are a bit of a mess at the moment. Someone needs to write an article for beginners (HA 101) that explains all of the installation methods with a flowchart or something and makes clear the differences between all of them. Because itâs just the same q after same q on this forum re installation.
No offence meant to OP, it is confusing. Especially since if you go to http://hass.io it takes you to the main Home Assistant site, not even the landing page for Hass.io installation.
Would you tell me what Iâm running?
There is this hass.io and then hassbian and then home-assistant which I manually install
Iâm confused now⌠whatâs the different on all of these?
hassbian is a custom raspbian build with Home Assistant already included.
Home Assistant is the application that can run on any Python environment
HASS.IO is a custom image, that runs on ResinOS, that is a specialized DOCKER instance. Home Assistant runs in a special DOCKER container in this version.
The frustration levels are climbing every day with more and more people posting about their confusion with this. Nothing against you, itâs poor documentation, and I donât know how to properly word it in the documentation.
I had the same issues of not understanding all the different ways to install and run home assistant. I had almost no linux experience and zero raspberry pi experience when I first started using home assistant. Started on a windows machine which was a nightmare, moved to a raspberry pi with hassio which was much better. Of course the next issue was trying to follow articles and videos that use all those âsudo apt-getâ commands which donât work with hassio. These issues are probably minor and obvious to many, but they caused many hours of frustration for me. Resin OS and dockers are still foreign concepts to me. Jinja also seems like a cruel joke on noobs like me.
yeah. what most people fail to realize with hassio is that the things they tend to find old documentation for, are things that are available as add-ons or already included in the hassio docker image.
one problem with updating the documentation is that it needs to be updated across all components as well. This is a major undertaking.
Does 433MHz code sniffing fall under that caregory? I got the RF transmitter and receiver for xmas and it seems like i wont be able to sniff the codes with hassio. Is that an incorrect statement?
Yes, it plugs directly into the raspberry pi. There are many threads that talk about it on this site. They all seem to require commands that can not be run on hassio.
The part that seems to be the roadblock is running python scripts to sniff the actual codes that are used. I took a look at the resinos documentation when I first setup hassio. There was a link to resinos documentation to setup hassio to be used with wifi instead of wired ethernet. I didnât even know where to begin and there werenât any step by step instructions. Kind of like saying, âyou are randomly going to china and you donât speak the language? No big deal, here is a book that teaches you chinese.â Itâs a pretty daunting taskâŚ
I will probably use a 2nd SD card and try to put something like raspian on it so i can follow the instructions on the threads on this site. That seems like the most likely path to success with my limited skill set.
Once i sniff the codes, I think i can go back to hassio without issues. Weâll see if that works.
I have been using Linux for around 17 years, have been programming arduino, esp8266 chips, and writing python on my PIs for the last couple of years. I have been in IT for 12 yearsâŚ
and even I was confused when I first read the resinOS docs on configuring networks. I had attempted to use ResinOS by itself right around the time that hassio was starting to go into beta, and it is a nightmare of an OS to configure and use. I get why they went that route for an âapplianceâ, but really it is more trouble than itâs worth. Now that it is the âpreferredâ method of installation, it draws in more and more confusion every single dayâŚ
