This is a test. It can also be replaced with my other devices. Improve the status update. I want to know what the code is like
I didnāt understand a lot when I just played this, or if you can, tell me where to read the platform. I donāt know what this means
Please donāt keep starting duplicate threads to ask the same question.
How did you add the light to home assistant? If you added it through the UI, you cannot add scan_interval to the configuration.
Honestly if you want lights that react more quickly, get bulbs that donāt rely on polling.
The problem is not the light, but the scanning interval. Itās OK to start it manually. There is a serious delay in automationā
Yeah well, local polling, thatās what you get.
Can you teach me how to increase the scan interval? I want to make automation faster
In configuration.yaml.
Iāve just started to contact Hass. Can I be more specific and how to configure it
Itās explained in my previous post that includes a link to the custom integrationās documentation.
Listen, you canāt just set scan interval on any entity. It depends on how you added the light to ha. So you have to answer the question; how did you add this to HA. If 123 is correct in assuming youāre using the custom integration, you need to follow the directions he linked.
