Help! How to repair my HA install?
Hi.
I was playing with custom components and was installing things that probably should not have installed through ssh =( now my bluetooth device reports issues:
2021-05-23 19:36:00 INFO (SyncWorker_6) [pygatt.backends.gatttool.gatttool] Starting BLE scan
2021-05-23 19:36:02 ERROR (SyncWorker_6) [pygatt.backends.gatttool.gatttool] No BLE adapter found
2021-05-23 19:36:02 ERROR (SyncWorker_6) [homeassistant.components.bluetooth_le_tracker.device_tracker] Error during Bluetooth LE scan: No BLE adapter found
2021-05-23 19:36:51 DEBUG (MainThread) [homeassistant.components.bluetooth_tracker.device_tracker] Performing Bluetooth devices discovery and update
2021-05-23 19:36:51 ERROR (MainThread) [homeassistant.components.bluetooth_tracker.device_tracker] Error looking up Bluetooth device
File "/usr/local/lib/python3.8/site-packages/bluetooth/bluez.py", line 30, in discover_devices
results = _bt.hci_inquiry (sock, duration=duration, flush_cache=True,
_bluetooth.error: (9, 'Bad file descriptor')
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 138, in perform_bluetooth_update
devices = await hass.async_add_executor_job(discover_devices, device_id)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 56, in discover_devices
result = bluetooth.discover_devices(
File "/usr/local/lib/python3.8/site-packages/bluetooth/bluez.py", line 34, in discover_devices
raise BluetoothError ("error communicating with local "
bluetooth.btcommon.BluetoothError: error communicating with local bluetooth adapter
hello,
do you use ble tacking?
are you under a docker install?
I am using it for bt/ble tracking. HA cannot find the controller now.
I am running it on NUC through HassOS install direct
