Hi there
i’m trying to run a python script to turn on my projector https://github.com/R3MRUM/sonyp_rs232c
now i can run the script (toggle_power.py) by going to the directory /sonyp_rs232c/test/ then typing “python3 toggle_power.py” in the terminal turns on my projector with no problem…
now i have tried to follow other peoples configuration.yaml files
but mine dose’nt seem to work is there something i’m missing??
switch:
- platform: command_line
switches:
sonyp_rs232c:
command_on: “python3 /home/homeassistant/.homeassistant/python_scripts/sonyp_rs232c/toggle_power.py”
command_off: “python3 /home/homeassistant/.homeassistant/python_scripts/sonyp_rs232c/toggle_power.py”
friendly_name: Projector
Can you format your code so it looks like it’s supposed to?
I have no idea how to do that im a noob
Python_scripts are not used in that way.
I take it somewhere in your configuration you have
python_script:
If so, in your service panel, in the drop down list you should see the python_script(s), something like…
Then if you want a ‘button’ on your front end, you can add a script to your configuration:
script:
python_toggle_power:
alias: Toggle Projector
sequence:
- service: python_script.toggle_power
Then when you press ACTIVATE on the front end, your python script will run.
Hope this helps.
Hi so i what i did at first was made a folder in my .homeassistant/ directory called “python_script” and i put the folder “sonyp_rs232c” in there
So thats what i thought but guess i was wrong
The directory needs to be called python_scripts (with an S on the end).
See the big blue box at the top of the page?
To MF_social
I changed the directory to python_scripts…
So do I just put this in the configuration. Yaml
