aircon_auto:
friendly_name: Aircon
icon_template: mdi:fan
value_template: "{{ states('climate.hitachi_ac') != 'off' }}"
turn_on:
- service: climate.set_temperature
entity_id: climate.hitachi_ac
data_template:
temperature: >
{% if states('sensor.pudong_temperature') | float < 15 %}
30
{% elif states('sensor.pudong_temperature') | float > 25 %}
27
{% else %}
25
{% endif %}
hvac_mode: >
heat
cool
{% else %}
fan_only
{% endif %}
turn_off:
- service: climate.turn_off
Heating while cold and cooling while warm, but 2 attr need to be set.
The code looks ugly, I’ve tried output json in data, but not work.
If split the code to script, that waste more code and more thing in “all script”, not so good.
( BTW, is that some way to hide script or switch in “all_*”? )
So, is that any way I missed? Please help.
