Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/init.py:705
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 5:34:02 AM (1 occurrences)
Last logged: 5:34:02 AM
[547599179904] The system cannot restart because the configuration is not valid: Integration error: trigger - Integration ‘trigger’ not found. Integration error: hsts - Integration ‘hsts’ not found. Integration error: customize - Integration ‘customize’ not found. Integration error: keyfile - Integration ‘keyfile’ not found. Integration error: action - Integration ‘action’ not found. Integration error: domain - Integration ‘domain’ not found. Integration error: certfile - Integration ‘certfile’ not found.
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 199, in handle_call_service
await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 1713, in async_call
task.result()
File “/usr/src/homeassistant/homeassistant/core.py”, line 1750, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File “/usr/src/homeassistant/homeassistant/components/hassio/init.py”, line 705, in async_handle_core_service
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Integration error: trigger - Integration ‘trigger’ not found.
