Can anyone help me to understand the reason of my home assistant crashes? Do I see this right, that the bluetooth scanning is causing the crash?
Here is the full crash file
2023-07-29 21:55:07.049 DEBUG (MainThread) [custom_components.hacs] <HacsData async_write> Saving data
2023-07-29 21:55:07.207 DEBUG (MainThread) [custom_components.hacs] <HACSStore async_save_to_store> Did not store data for 'hacs.repositories'. Content did not change
2023-07-29 21:55:07.341 INFO (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Pool recreating
2023-07-29 21:55:07.344 WARNING (MainThread) [homeassistant.core] Task <Task pending name='Task-4396322' coro=<async_install() running at /usr/src/homeassistant/homeassistant/components/update/__init__.py:156> wait_for=<Future pending cb=[Task.task_wakeup()]> cb=[set.remove(), Task.task_wakeup()]> was still running after stage 2 shutdown; Integrations should cancel non-critical tasks when receiving the stop event to prevent delaying shutdown
2023-07-29 21:55:07.352 WARNING (MainThread) [homeassistant.core] Task <Task pending name='Task-861744' coro=<HaScanner._async_restart_scanner() running at /usr/src/homeassistant/homeassistant/components/bluetooth/scanner.py:348> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.11/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]> was still running after stage 2 shutdown; Integrations should cancel non-critical tasks when receiving the stop event to prevent delaying shutdown
2023-07-29 21:55:12.362 WARNING (MainThread) [homeassistant.runner] Task could not be canceled and was still running after shutdown: <Task cancelling name='Task-689952' coro=<WebSocketCommonProtocol.close_connection() running at /usr/local/lib/python3.11/site-packages/websockets/legacy/protocol.py:1312> wait_for=<Future pending cb=[shield.<locals>._outer_done_callback() at /usr/local/lib/python3.11/asyncio/tasks.py:898, Task.task_wakeup()]>>
2023-07-29 21:55:12.442 WARNING (Thread-119 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_12] is still running at shutdown: File "/usr/local/lib/python3.11/threading.py", line 995, in _bootstrap
self._bootstrap_inner()
File "/usr/local/lib/python3.11/threading.py", line 1038, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.11/threading.py", line 975, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 83, in _worker
work_item.run()
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
2023-07-29 21:55:13.437 WARNING (Thread-119 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_12] is still running at shutdown: File "/usr/local/lib/python3.11/threading.py", line 995, in _bootstrap
self.run()
work_item.run()
2023-07-29 21:55:15.216 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback async_track_point_in_utc_time.<locals>.run_action(<Job time cha...0x7f89ea4e00>>) at /usr/src/homeassistant/homeassistant/helpers/event.py:1350
File "/usr/local/lib/python3.11/asyncio/events.py", line 80, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1365, in run_action
hass.async_run_hass_job(job, utc_point_in_time)
File "/usr/src/homeassistant/homeassistant/core.py", line 627, in async_run_hass_job
hassjob.target(*args)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1619, in pattern_time_change_listener
hass.async_run_hass_job(job, dt_util.as_local(now) if local else now)
File "/usr/src/homeassistant/homeassistant/core.py", line 630, in async_run_hass_job
return self.async_add_hass_job(hassjob, *args)
File "/usr/src/homeassistant/homeassistant/core.py", line 533, in async_add_hass_job
task = self.loop.run_in_executor(None, hassjob.target, *args)
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 822, in run_in_executor
self._check_default_executor()
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 523, in _check_default_executor
raise RuntimeError('Executor shutdown has been called')
RuntimeError: Executor shutdown has been called
2023-07-29 21:55:22.440 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_12] is still running at shutdown: File "/usr/local/lib/python3.11/threading.py", line 995, in _bootstrap
self.run()
work_item.run()
2023-07-29 21:55:23.433 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_12] is still running at shutdown: File "/usr/local/lib/python3.11/threading.py", line 995, in _bootstrap
self.run()
work_item.run()
