Help in setting 'Fibaro Window Shutter 2' as cover with MQTT
Hi good people,
I’m trying to set the fibaro window shutter 2 as cover, but I can’t seem to make it work…
I use smartthings hub to connect to the window shutter and smartthings is sanding to mqtt.
I managed to configure the lights OK, but I can’t get the window shutter to work… :confused:
I can see the device is publish correctly in mosquito-mqtt
smartthings/Living Room Light/level 98
When I try to control it throw homeAssistant, I get this:
smartthings/Window Shutter/level OPEN
smartthings/Window Shutter/level CLOSE
smartthings/Window Shutter/level STOP
But the window shutter doesn’t move. :confounded:
I realize it got something to do with the fact that home assistant is sending words (UP/DOWN/STOP) instead of level values, but I do not know where to start…
here is my settings:
cover:
  brightness_command_topic: "smartthings/Window Shutter/level"
  brightness_scale: 100
  brightness_state_topic: "smartthings/Window Shutter/level"
  payload_off: "off"
  payload_on: "on"
  platform: mqtt
  retain: true
Please help my understand what I’m missing…
Thanks.
Gil. :slight_smile:
