I just noticed that Android App added the bluetooth sensor so I started to define a way to track where my car is based on my mobile position and store it to make it persistend during reboot.
This is what I’ve done so far based on others solution found in the forum:
automation:
- id: grab_position_from_marco
alias: Posizione Renata da Marco
initial_state: true
value_template: >
{% if
(is_state_attr('sensor.mi_6_bluetooth_connection', 'connected_paired_devices', '74:95:EC:0A:9A:AA')) %}
true
{% endif %}
mode: queued
repeat:
while:
- condition: template
value_template: >
{% if
true
{% endif %}
sequence:
- service: notify.mobile_app_mi_6
message: "request_location_update"
- service: device_tracker.see
data_template:
dev_id: renata
host_name: 'Renata'
source_type: gps
mac: '74:95:EC:0A:9A:AA'
location_name: "{{ states('sensor.mi_6_geocoded_location') }}"
gps_accuracy: "{{ states.person.marco.attributes.gps_accuracy }}"
gps:
- "{{ state_attr('person.marco', 'latitude') }}"
- "{{ state_attr('person.marco', 'longitude') }}"
- delay:
minutes: 10
This worked once (device_tracker was created) but then nothing.
For storing I’ve tried to “recycle” a solution found on another post but it seems that “value_template: {{ trigger.to_state.state }}” is wrong. But how to allow this automation to store every position saved regardless of the state?
variable:
car_tracker_backup:
restore: true
value: home
attributes:
friendly_name: 'Car tracker backup'
automation:
- id: backup_tracker_data
alias: Backup custom device trackers
description: Use a variable to persist custom device tracker data across resets
- entity_id: device_tracker.renata
platform: state
condition: []
- service: variable.set_variable
variable: car_tracker_backup
attributes_template: >
"source_type": "{{ trigger.to_state.attributes.source_type }}",
"latitude": "{{ trigger.to_state.attributes.latitude }}",
"longitude": "{{ trigger.to_state.attributes.longitude }}",
"gps_accuracy": "{{ trigger.to_state.attributes.gps_accuracy }}",
"host_name": "{{ trigger.to_state.attributes.friendly_name }}"
- id: restore_trackers_on_startup
alias: Restore custom device trackers
description: Restore data for custom device trackers on startup
- event: start
platform: homeassistant
condition: []
data_template:
dev_id: car
host_name: "{{ state_attr('variable.car_tracker_backup', 'host_name') }}"
location_name: "{{ states('variable.car_tracker_backup') }}"
gps:
- "{{ state_attr('variable.car_tracker_backup', 'latitude') }}"
- "{{ state_attr('variable.car_tracker_backup', 'longitude') }}"
gps_accuracy: "{{ state_attr('variable.car_tracker_backup', 'gps_accuracy') }}"
Thank you in advance to all the hints and suggestions!
