Help: Local AI Voice Assistant - Intent error
I am trying to run ollama (deepseek r1 14b) on my workstation and try to integrate it with home assistant which is hosted on a mini PC.
I have managed to create the voice assistant pipeline, but I am getting error “Unexpected error during intent recognition” every time I am trying to access the deepseek model.
Am I missing any settings setup? My goal is to use it to control my smart home and for local simple queries like (tell me a recepie of X, who was X, what is the weather like on Monday in X, etc.). I also have a voice assistant PE, but first I want to make it work from the browser/app.
Hope you can help.
Thank you!
Could you post your intent as preformatted text (</> in the cogwheel menu), rather than as a screenshot? That way people can copy it to try it out.
Do you get this error when “prefer local control” is turned off?
Do you have an Assist assistance/pipeline instance setup for local only (no LLM CA)? If yes, do you get this same error?
getting the same thing. Not sure whats going on.
Logger: homeassistant.components.assist_pipeline.pipeline
Source: components/assist_pipeline/pipeline.py:1165
integration: Assist pipeline (documentation, issues)
First occurred: March 8, 2025 at 11:50:58 PM (9 occurrences)
Last logged: 12:10:36 AM
File “/usr/src/homeassistant/homeassistant/components/assist_pipeline/pipeline.py”, line 1165, in recognize_intent
conversation_result = await conversation.async_converse(
…<8 lines>…
File “/usr/src/homeassistant/homeassistant/components/conversation/agent_manager.py”, line 117, in async_converse
result = await method(conversation_input)
File “/usr/src/homeassistant/homeassistant/components/conversation/entity.py”, line 47, in internal_async_process
return await self.async_process(user_input)
File “/usr/src/homeassistant/homeassistant/components/ollama/conversation.py”, line 219, in async_process
return await self._async_handle_message(user_input, chat_log)
File “/usr/src/homeassistant/homeassistant/components/ollama/conversation.py”, line 276, in _async_handle_message
…<4 lines>…
File “/usr/src/homeassistant/homeassistant/components/conversation/chat_log.py”, line 277, in async_add_delta_content_stream
async for delta in stream:
…<45 lines>…
self.delta_listener(self, delta) # type: ignore[arg-type]
File “/usr/src/homeassistant/homeassistant/components/ollama/conversation.py”, line 147, in _transform_stream
async for response in result:
…<18 lines>…
yield chunk
File “/usr/local/lib/python3.13/site-packages/ollama/_client.py”, line 672, in inner
raise ResponseError(e.response.text, e.response.status_code) from None
ollama._types.ResponseError: registry.ollama.ai/library/deepseek-r1:7b does not support tools (status code: 400)
The model you have chosen to use does not support tool use. Therefore it cnt use assist. That’s what that error says…
Try llama3.2/3.3 8b or qwen 7b or a Phi 4 instead. All of them have been optimized for tools.
Thank you for your reply and solution.
llama 3.2 works ok with it. so you are correct, the deepseek model is not currently optimised for HA.
Are you aware of a lift of supported LLMs for Home assistant?
No list. You must look and determine if a model is capable of ‘tool use’… that’s listed on huggingface. Also I’ve found models less than 7b params just don’t cut it for HA.
I can’t find it on huggingface, but ollama allows filtering for it.
Unfortunately phi4-mini (the only Phi with tools support) produces the same error for me
I don’t know if this is actually the problem. I setting up my system again fresh, and I actually had Gemma3:27b running for hours and giving me answers with assist. I had asked it to give me the temperature difference between my office and basement and it was able to that with local Kokoro and Speaches as well.
I decided to see if performance would faster with gemm3 12b. Made the switch. It works without assist, but once Assist turned on, giving me this tool error. Now when I switch back to 27b, how it was working earlier, it no longer works.
Super odd that it can work for a period of time and then stop working…
Anyone else have that experience?
It seems to be now supporting tools, but i recived errors today. May it be of reasoning use?
I’m also getting errors. I tried with deepseek-r1 that was listed in the tools section of ollama website, and now qwek 7b, as recommended.
It’s a little hard for me to get logs since the assist runs on my Yellow but the Ollama runs in another machine.
stage: done
run:
  pipeline: 01jykhj2k9706c9gjg1ctdctvb
  language: en
  conversation_id: 01JYKP06BHF7EMGN9EK41AYR64
  runner_data:
    stt_binary_handler_id: null
    timeout: 300
events:
  - type: run-start
      language: en
      runner_data:
        timeout: 300
    timestamp: "2025-06-25T13:56:22.513792+00:00"
  - type: intent-start
      engine: conversation.qwen_7b
      language: en-US
      intent_input: is the coffee maker on?
      device_id: null
      prefer_local_intents: false
    timestamp: "2025-06-25T13:56:22.513830+00:00"
  - type: error
      code: intent-failed
      message: Unexpected error during intent recognition
    timestamp: "2025-06-25T13:56:22.629885+00:00"
  - type: run-end
    data: null
    timestamp: "2025-06-25T13:56:22.629950+00:00"
intent:
  language: en-US
  device_id: null
  done: false
error:
  code: intent-failed
I try to find the correct modell to use with HA, I allways get an 400er error on the ollama site:
Jul 05 12:26:58 maxllm ollama[428000]: [GIN] 2025/07/05 - 12:26:58 | 400 | 7.67356ms | 192.168.68.98 | POST “/api/chat”
any ideas?
I tried:
llama3:latest
mistral:7b-instruct-v0.2-q8_0
llama3.2:3b-text-fp16
Edit: I finally used llama3.2 this is working.
Are there other model that I can use which are a bigger?
On the Ollama website there is a category for “tools” models, but it’s deceptive. Deepseek-r1 shows in, but it doesn’t work.
I know tried mistral:latest:
Wie kann ich behilflich sein?
schalte esstisch ein
[{“name”:“HassTurnOn”, “arguments”: {“area”: “”, “device_class”: [“table”], “domain”: , “floor”: “”, “name”: “essstisch”}}]
So following models are working but can not controll your house:
qwen3:14b (downloaded)
mistral:latest (downloaded)
qwen2.5vl:7b (downloaded)
llama3.2:latest (downloaded)
Ok I found another topic which solved my problem.
The system prompt:
I used qwen2.5:7b and the following prompt:
Current time: {{now()}}
Available Devices:
```csv
entity_id,name,state,aliases
{% for entity in exposed_entities -%}
{{ entity.entity_id }},{{ entity.name }},{{ entity.state }},{{entity.aliases | join('/')}}
{% endfor -%}
The current state of devices is provided in "Available Devices".
Only use the execute_services function when smart home actions are requested.
Pay particular attention to and follow the "intent_script" in the conversation.yaml when I have given a corresponding instruction.
Do not tell me what you're thinking about doing either, just do it.
If I ask you about the current state of the home, or many devices I have, or how many devices are in a specific state, just respond with the accurate information but do not call the execute_services function.
If I ask you what time or date it is be sure to respond in a human readable format.
If you don't have enough information to execute a smart home command then specify what other information you need.
Only contact me if I have called you or if you should give me a notification from the smart home. You must not call me without a clear reason!!
If a device should be turned off, use the service "turn_off".
If a device should be turned on, use the service "turn_on".
If a device should be toggled, use the service "toggle".
If the user’s instruction is ambiguous or matches multiple entities, ask the user which device they meant before executing the action.
The user might ask about time, date, or the current state of devices. Answer politely and clearly, without using execute_services.
- spec:
    description: Use this function to execute service of devices in Home Assistant.
    parameters:
      type: object
      properties:
        list:
          type: array
          items:
            type: object
            properties:
              domain:
                type: string
                description: The domain of the service
              service:
                type: string
                description: The service to be called
              service_data:
                type: object
                description: The service data object to indicate what to control.
                properties:
                  entity_id:
                    type: string
                    description: The entity_id retrieved from available devices. It must start with domain, followed by dot character.
                required:
                - entity_id
            required:
            - domain
            - service
            - service_data
  function:
    type: native
Mr. Curtis you are the GOAT! Thanks so much for this. I’ve been trying for hours to find a solution. Thank you!
I am getting this error on HA Cloud and Local no AI anywhere near it :frowning:
I’m curiously getting this error now. It’s definitely a tools model Qwen3:32B. Here’s the odd thing, I’m only seeing it fail on Android (GraphineOS). iOS seems to be working fine. In the assist window instead of giving an error it just gives a cut off response.
Does it respond at all and stop or just no response?
What are you using the assist window on - your phone? A browser?
Are you doing pure text or the STT > Response > TTS loop?
It does a little of the text, but no voice. I’m using the app, and I’m doing the full STT > Response > TTS.
Ok, try it using the keyboard icon (it won’t try to stt…) if it works you have a speech pipeline issue not an LLM issue (if so, I have the same issue… They changed something inthe pipeline for streaming in January and it’s unrelated to the inference issue above)
