Having reached the point where I’m almost about to throw everything out of the house, I decided to give it one more try through the HA community to find out what exactly is causing my config to be so unstable.
Below an extract of my log since last reboot… And as you can see, it’s just beyond acceptable, the number of errors… Typically, in the morning when I wake up or in the evening when I come home, I’m having endless logs with errors like this… Every morning, it’s waiting to see if my morning routine will start. Sometimes it does, sometimes it doesn’t, sometimes there is a delay on some parts…
I tried reinstalling from scratch, I tried deactivating certain components, I tried optimizing my network, I really think that I’ve considered all what is possible, including making sure template sensors only update based on changed for certain entity_ids, no discovery, etc… etc… I considered swapping my hardware as I wondered if the RPI 3 can handle all this, bu
For those interested or wanting to have a look, my config is here: https://github.com/farstreet/my-home-assistant-configuration It has an overview of my hardware used and of course you can look into the different component configs and automations. Current DB size is about 225 MB, I have purge on 1 day but I never get to 24h without rebooting, so that’s happing never…
I shared my config initially to help people with their setups, right now I need help from the community back
If there’s anyone in Northern California (SF South Bay), I got to the point that I’m willing to pay for support
17-04-12 23:35:25 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
17-04-12 23:35:30 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
17-04-12 23:35:46 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
17-04-12 23:35:58 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
17-04-12 23:36:55 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
17-04-12 23:36:55 WARNING (Thread-15) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-12 23:36:55 WARNING (Thread-22) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-12 23:36:55 WARNING (Thread-19) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-12 23:36:55 WARNING (Thread-16) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-12 23:36:55 WARNING (Thread-18) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-12 23:36:55 WARNING (Thread-21) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-12 23:36:55 WARNING (Thread-17) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-12 23:36:55 WARNING (Thread-20) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-12 23:36:55 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.all_living_room_lights is taking over 10 seconds.
17-04-12 23:36:55 WARNING (Thread-14) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-12 23:38:24 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
17-04-12 23:38:24 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.uberx_time is taking over 10 seconds.
17-04-12 23:38:24 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.bednightlamp_jurgen is taking over 10 seconds.
17-04-12 23:38:24 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.living_room_thermostat_operation_mode is taking over 10 seconds.
17-04-12 23:38:24 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.travel_work_benoit_to_work_jurgen is taking over 10 seconds.
17-04-12 23:38:24 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.maximum_disk_temp_volume_2 is taking over 10 seconds.
17-04-12 23:38:24 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.soundtouch_bathroom is taking over 10 seconds.
17-04-12 23:38:24 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.bureaustandinglampbulb1 is taking over 10 seconds.
17-04-12 23:38:25 WARNING (MainThread) [homeassistant.components.light] Updating hue light took longer than the scheduled update interval 0:00:30
17-04-12 23:38:25 WARNING (MainThread) [homeassistant.components.sensor] Updating uber sensor took longer than the scheduled update interval 0:00:30
17-04-12 23:38:25 WARNING (MainThread) [homeassistant.components.light] Updating flux_led light took longer than the scheduled update interval 0:00:30
17-04-12 23:38:25 WARNING (MainThread) [homeassistant.components.sensor] Updating nest sensor took longer than the scheduled update interval 0:00:30
17-04-12 23:38:25 WARNING (MainThread) [homeassistant.components.sensor] Updating google_travel_time sensor took longer than the scheduled update interval 0:00:30
17-04-12 23:38:25 WARNING (MainThread) [homeassistant.components.sensor] Updating synologydsm sensor took longer than the scheduled update interval 0:00:30
17-04-12 23:38:25 WARNING (MainThread) [homeassistant.components.media_player] Updating soundtouch media_player took longer than the scheduled update interval 0:00:10
17-04-12 23:46:12 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal read error on socket transport
File "/usr/lib/python3.4/asyncio/selector_events.py", line 582, in _read_ready
data = self._sock.recv(self.max_size)
OSError: [Errno 113] No route to host
17-04-12 23:53:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.soundtouch_bathroom is taking over 10 seconds.
17-04-12 23:53:04 WARNING (MainThread) [homeassistant.components.media_player] Updating soundtouch media_player took longer than the scheduled update interval 0:00:10
17-04-12 23:53:15 WARNING (MainThread) [homeassistant.components.media_player] Updating soundtouch media_player took longer than the scheduled update interval 0:00:10
17-04-12 23:53:26 WARNING (MainThread) [homeassistant.components.media_player] Updating soundtouch media_player took longer than the scheduled update interval 0:00:10
17-04-12 23:53:37 WARNING (MainThread) [homeassistant.components.media_player] Updating soundtouch media_player took longer than the scheduled update interval 0:00:10
17-04-12 23:53:48 WARNING (MainThread) [homeassistant.components.media_player] Updating soundtouch media_player took longer than the scheduled update interval 0:00:10
17-04-13 00:02:27 WARNING (Thread-14) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-13 00:02:27 WARNING (Thread-22) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-13 00:02:27 WARNING (Thread-15) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-13 00:02:27 WARNING (Thread-20) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-13 00:02:26 WARNING (Thread-16) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-13 00:02:27 WARNING (Thread-17) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-13 00:02:27 WARNING (Thread-19) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-13 00:02:27 WARNING (Thread-21) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-13 00:02:27 WARNING (Thread-18) [pychromecast.socket_client] Heartbeat timeout, resetting connection
17-04-13 00:02:29 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
17-04-13 00:02:26 ERROR (Thread-8) [homeassistant.components.sensor.speedtest] Error executing speedtest: Command '['/srv/homeassistant/bin/python3', '/home/homeassistant/.homeassistant/deps/speedtest.py', '--simple']' returned non-zero exit status -9
17-04-13 00:02:31 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from nmap_tracker took longer than the scheduled scan interval 0:00:20
17-04-13 00:02:32 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
17-04-13 00:07:35 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
17-04-13 00:07:38 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.soundtouch_bathroom is taking over 10 seconds.
