vipk31
(vipk31)
October 12, 2019, 3:50am
1
I am currently having problems
Configure my settings
title: test
icon: 'mdi:script'
panel: true
path: mirror
cards:
- type: 'custom:layout-card'
layout: horizontal
column_num: 3
ltr: false
rebuild: false
cards:
- type: custom:clock-card
entity: sensor.time
# thoi tiet
- type: custom:weather-card
entity: weather.home_tnt
icons: "/local/icons/"
its is show
But I would like to show it as shown below
I took a long time but still could not do it. Is there anyone to help me. Thank you very much
Sorry for the tag:
@thomasloven
VDRainer
October 12, 2019, 5:46am
2
Have you tried it with the break?
cards:
entity: sensor.time
- break
- break # not sure if you need a second one in horizontal layout
# thoi tiet
Or you can try the gap-card to insert a dummy card.
tom_l
October 12, 2019, 6:39am
3
The gap card is a godsend. I only discovered it recently but it has enabled the layouts I want.
vipk31
(vipk31)
October 12, 2019, 6:48am
4
thanks you very much !!
The gap-card has solved the problem
That’s exactly what it’s for. Should probably have been bundled with layout-card…
tom_l
October 12, 2019, 9:53pm
6
Doesn’t the layout card require panel mode though?
