Hi all,
I recently bought ESP32-3248S035 (https://tinyurl.com/nwttm4xw) and trying to get the right configuration to get it up and running (screen/touch).
Did anyone have any success in that?
Thank you so much!
Hi all,
Thank you so much!
Try Googling the board name and doing some digging. This page platformio-espressif32-sunton/esp32-3248S035C.json at 59ec63edd07c4d5d75d5b1e46083c2ab6446ab46 · rzeldent/platformio-espressif32-sunton · GitHub suggests that’s an ST7796 display driver, which is supported by the ili9xxx ESPHome component, so you just need to set up the correct pins for SPI and the display control lines.
There is no PSRAM so it’s unlikely the ESPHome display drawing functions will work, but LVGL with a 25% buffer_size should be ok.
The capacitive touch version appears to use a GT911 which is also supported in ESPHome.
There is some info here, and it does say they have psram. ESP32-3248S035 - openHASP
That page says 8MB PSRAM at the top, but later in 2 places it says no PSRAM.
Thanks for the help, I’ve tried setting the configuration, and get the following:
[23:40:00][C][logger:185]: Logger:
[23:40:00][C][logger:186]: Level: DEBUG
[23:40:00][C][logger:188]: Log Baud Rate: 115200
[23:40:00][C][logger:189]: Hardware UART: UART0
[23:40:00][C][spi:068]: SPI bus:
[23:40:00][C][spi:069]: CLK Pin: GPIO14
[23:40:00][C][spi:070]: SDI Pin: GPIO12
[23:40:00][C][spi:071]: SDO Pin: GPIO13
[23:40:00][C][spi:076]: Using HW SPI: SPI
[23:40:00][C][spi:069]: CLK Pin: GPIO18
[23:40:00][C][ledc.output:181]: Bit depth: 16
[23:40:00][C][ledc.output:176]: LEDC Output:
[23:40:00][C][ledc.output:177]: Pin GPIO4
[23:40:00][C][ledc.output:178]: LEDC Channel: 1
[23:40:00][C][ledc.output:179]: PWM Frequency: 1000.0 Hz
[23:40:00][C][ledc.output:180]: Phase angle: 0.0°
[23:40:00][C][ledc.output:177]: Pin GPIO16
[23:40:00][C][ledc.output:178]: LEDC Channel: 2
[23:40:00][C][ledc.output:177]: Pin GPIO17
[23:40:00][C][ili9xxx:094]: Dimensions: 320px x 480px
[23:40:00][C][ili9xxx:095]: Width Offset: 0
[23:40:00][C][ili9xxx:105]: Color mode: 8bit 332 mode
[23:40:00][C][ili9xxx:111]: Data rate: 40MHz
[23:40:00][C][ili9xxx:114]: CS Pin: GPIO15
[23:40:00][C][ili9xxx:115]: DC Pin: GPIO2
[23:40:00][C][ili9xxx:117]: Color order: BGR
[23:40:00][C][ili9xxx:118]: Swap_xy: NO
[23:40:00][C][ili9xxx:119]: Mirror_x: YES
[23:40:00][C][ili9xxx:120]: Mirror_y: NO
[23:40:00][C][ili9xxx:123]: => Failed to init Memory: YES!
[23:40:00][C][ili9xxx:125]: Update Interval: 1.0s
[23:40:00][E][component:082]: Component display is marked FAILED
[23:40:00][C][light:103]: Light 'LED'
[23:40:00][C][light:105]: Default Transition Length: 1.0s
[23:40:00][C][light:106]: Gamma Correct: 2.80
[23:40:00][C][esp32_improv.component:261]: ESP32 Improv:
[23:40:00][C][esp32_improv.component:266]: Status Indicator: 'NO'
[23:40:00][C][captive_portal:088]: Captive Portal:
[23:40:00][C][web_server:173]: Web Server:
[23:40:00][C][web_server:174]: Address: esphome-web-4560ec.local:80
[23:40:00][C][mdns:115]: mDNS:
[23:40:00][C][mdns:116]: Hostname: esphome-web-4560ec
[23:40:00][C][esphome.ota:073]: Over-The-Air updates:
[23:40:00][C][esphome.ota:074]: Address: esphome-web-4560ec.local:3232
[23:40:00][C][esphome.ota:075]: Version: 2
[23:40:00][C][safe_mode:018]: Safe Mode:
[23:40:00][C][api:140]: Address: esphome-web-4560ec.local:6053
The configuration I’m using is:
spi:
- id: tft
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
- id: touch
clk_pin: GPIO18
mosi_pin: GPIO23
miso_pin: GPIO19
display:
- platform: ili9xxx
model: ST7796
cs_pin: GPIO15
dc_pin: GPIO2
spi_id: tft
Any thoughts what I still might be missing?
Thanks!
Yes, you are right, that needs fixing doesn’t it, and careful reading.
Like I said, it won’t work with the standard display operations due to insufficient memory. You’ll need update_interval: never and auto_clear_enabled: false then use LVGL - LVGL implementation for ESPHome by clydebarrow · Pull Request #6363 · esphome/esphome · GitHub - read the docs linked there and make sure to set buffer_size: 25%
Also best to log via UART so you capture all the messages after startup.
I struggled getting this to work as well, but it works fine with Openhasp if you want it to just work. I’ve realised I’m not a big fan of that software though and I also plan to add some controls to the device which would be easier using Esphome.
[edit]: I forgot to change the buffer size, now it works!
So I tried @clydebarrow’s suggestions and that works. I used the following yaml for a hello world example:
esphome:
friendly_name: TV-controller
external_components:
- source: github://pr#6363
refresh: 10min
components: [lvgl]
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
platform: esphome
password: "xxx"
wifi:
ssid: !secret wifi_ssid
i2c:
sda: 33
scl: 32
scan: true
spi:
clk_pin: 14
mosi_pin: 13
miso_pin: 12
light:
- platform: rgb
red: red_GPIO
green: green_GPIO
blue: blue_GPIO
- platform: monochromatic
output: backlight_pin
name: "Display Backlight"
restore_mode: ALWAYS_ON
output:
- platform: ledc
pin: 4
inverted: True
- platform: ledc
pin: 16
inverted: True
- platform: ledc
pin: 17
inverted: True
- platform: ledc
pin: 27
display:
- platform: ili9xxx
model: ST7796
dc_pin: 2
cs_pin: 15
dimensions: 320x480
touchscreen:
platform: gt911
update_interval: 50ms
# interrupt_pin: 21 # maybe not connected?
# reset_pin: 25 # From a openhasp config, appears to be the 'normal' esp32 reset pin?
color:
- id: my_red
red: 100%
green: 0%
blue: 0%
# font:
# - file: "gfonts://Martian+Mono"
# id: large
# size: 40
# id: small
# size: 20
lvgl:
touchscreens:
- my_touch
buffer_size: 25%
pages:
- id: main_page
widgets:
- label:
align: CENTER
text: 'Hello World!'
Yatush,
I was having all sorts of problems with the ESP32-3248S035C until I happened on the Annex RDS site and after that (if you know BASIC) it is easy - it does all the hard work for you just set the Config to ESP32-3248S035C and voila. The Annex RDS puts the BASIC in the chip and uses your WiFi to communicate with it.
Starraker
For all attempting to use the ESP32-3248S035C (or ESP32-3248S035R)
For Touch on these boards the following applies (GPIO Pins):
Resistive Touch : INT = 36, SCLK = 14, MOSI = 13, MISO =12, CS = 33 (XPT2046)
Capacitative Touch: INT = 21, SCL = 32, SDA = 33, RST = 25 (GT911)
The Resistive Touch needs to align the touchscreen before it can be used whereas the Capacitive Touch does not need this Step as it is prealigned.
LED1 has three GPIO pins : RED = 4, GREEN = 16, BLUE = 17
BACKLIGHT = GPIO 27
AUDIO AMP : GPIO 26 - Careful when using a speaker an 8 ohm speaker needs to have a series resistor to prevent overloading the amp.
GPIO 39 is unwired but can still be used
Careful with Capacitive Touch - pin 21 has two other definitions (min)
SCREEN SPI: DC = 2, SCLK = 14, MOSI = 13, MISO = 12, CS = 15 RST = EN(-1) - Please note the Screen SPI and Resistive Touch share SCLK, MOSI, & MISO
This board does not act like other ESP32 boards as many of the pins are hard wired and predefined. However , If you prefer easier manipulation / programming of this board go to Annex 32 Rapid Development Suite and use the BASIC Language where this board and its large number of capabilities are all accessible.
This is great board have fun.
I hope that this helps
Thanks for your valuable input, I got the display to work but have no contact at all to the touch functionality.
It does not output anything to the log when touching the screen and it does not react, og clicking a button.
This is not a hardware issue as it worked fine with default sw.
I wonder what I am missing.
Here is the relevant config part
i2c:
sda: GPIO33
scl: GPIO32
scan: true
touchscreen:
- platform: gt911
display: my_display
interrupt_pin: GPIO21
# reset_pin: GPIO25
# i2c_id: bus_a
# address: 0x5D
on_touch:
- lambda: |-
ESP_LOGI("cal", "x=%d, y=%d, x_raw=%0d, y_raw=%d",
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
- light.turn_on:
brightness: 100%
on_release:
then:
- if:
condition: lvgl.is_paused
then:
- lvgl.resume:
- lvgl.widget.redraw:
lvgl:
displays:
- my_display
touchscreens:
- my_touch
buffer_size: 25%
color_depth: 16
bg_color: room_bg_color #0
pad_all: 0
border_width: 0
border_color: HA_blue
outline_width: 0
shadow_width: 0
text_font: font_s
align: center
style_definitions:
- id: default_style # choose an ID for your definition
border_color: default_border_color
border_width: 0
align: CENTER
text_align: CENTER
pages:
- id: main_page
pad_all: 0
widgets:
- obj:
width: 480
height: 320
layout:
type: grid
grid_row_align: end
grid_columns: [fr(1)]
grid_rows: [fr(1), fr(2),fr(2),fr(2), fr(1)]
pad_row: 0px
pad_column: 0px
pad_all: 0px
outline_pad: 0px
widgets:
- label:
grid_cell_column_pos: 0
grid_cell_row_pos: 0
grid_cell_x_align: CENTER
grid_cell_y_align: CENTER
styles: default_style
text_font: font_l
pad_all: 0px
outline_pad: 0px
text: "Hello World"
- button:
grid_cell_row_pos: 1
grid_cell_x_align: STRETCH
grid_cell_y_align: STRETCH
pad_all: 0px
outline_pad: 0px
bg_color: default_button_bg_color
bg_grad_color: default_button_bg_grad_color
widgets:
- label:
text: "Test touch"
text_font: font_xs
on_click:
then:
- lvgl.label.update:
text: "Button pushed"
By the way, I am not able to set the RST pin for the touch. when compiling I get the error:
[reset_pin] is an invalid option for [touchscreen.gt911]. Please check the indentation.
Update your ESPHome version. reset_pin is valid, and is important. Check the serial logs for errors relating to the touchscreen and i2c.
Hi @clydebarrow,
Thanks for your input.
I updated to latest HA and ESPHome, then I was allowed to set the reset_pin. But it did not fix my problem.
After several trials, It started working when I removed the interrupt_pin.
Then I ended up removing both interrupt and reset pin as in @sophof example and it still works.
So, maybe there is an issue with Pin 21 (the interrupt pint) as it is used by other things as @Starraker1 mentioned “Careful with Capacitive Touch - pin 21 has two other definitions (min)”
Finally, I did not use github://pr#6363, as LVGL is natively supported by ESPHome now.
So, now it looks like I have the basics to work, then I go further with custom configuration to my use case.
Thanks ![]()
so how do we define both LCD and resistive touchscreen in esphome project?
figured: we shall assign same spi_id to both
Would you mind sharing your code if you have a working version?
Hi @TommySharpNZ ,
Yes I got it to work and here is a full working version:
esphome:
friendly_name: display3_5
esp32:
board: esp32dev
framework:
type: arduino #esp-idf #
# Enable logging
logger:
api:
encryption:
key: !secret api_encryption_key
ota:
- platform: esphome
password: !secret ota_password
wifi:
ap:
ssid: ${Myfriendly_name}
password: !secret ap_password
captive_portal:
color:
- id: room_bg_color
hex: CCFFCC #lygrøn
- id: room_image_color
hex: ff3399 #4d30ed #03a9f4 #4D30ED #mørkeblå
- id: room_image_bg_color
hex: ff4e03 #FF4E03 #mørke orange
- id: room_image_bg_grad_color
hex: FFFF00 #lys gul
#Generik colors
- id: HA_blue
hex: 03a9f4
- id: color_grey
hex: D1D0CE
- id: color_dark_grey
hex: A0A0A0
- id: default_border_color
hex: FF0000
- id: default_button_text_color
hex: FFFFFF
- id: sub_page_border_color
hex: FFFFFF
- id: sub_page_button_border_color
hex: FFFFFF
- id: default_button_bg_color
hex: 2F8CD8
- id: default_button_check_bg_color
hex: 1d5f96
- id: default_button_check_bg_grad_color
hex: 03324A
- id: default_button_check_text_color
hex: fff300
- id: sub_page_footer_pressed_button_bg_color
hex: FFFF00
- id: default_button_pressed_bg_color
hex: 006699
- id: default_button_pressed_bg_grad_color
hex: 00334d
- id: default_button_bg_grad_color
hex: 005782
- id: default_button_border_color
hex: 0077b3
font:
- file: "gfonts://Roboto"
output:
- platform: ledc
pin: GPIO27
- platform: ledc
pin: GPIO4
inverted: true
- platform: ledc
pin: GPIO16
inverted: true
- platform: ledc
pin: GPIO17
inverted: true
light:
output: backlight_pwm
name: '"Display Backlight"'
internal: True
on_turn_on:
then:
- light.turn_on:
brightness: 75%
red: 100%
green: 100%
blue: 100%
- platform: rgb
restore_mode: ALWAYS_OFF
red: led_red
green: led_green
blue: led_blue
internal: True
spi:
- id: spi_tft
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
display:
- platform: ili9xxx
model: ST7796
spi_id: spi_tft
dc_pin: GPIO2
cs_pin: GPIO15
dimensions:
width: 480
height: 320
data_rate: 80MHz #40MHz
color_order: RGB
invert_colors: false
show_test_card: false
transform:
swap_xy: true
mirror_y: false
mirror_x: false
i2c:
sda: 33
scl: 32
scan: true
touchscreen:
- platform: gt911 #xpt2046
display: my_display
# reset_pin: 25
# interrupt_pin: GPIO21
# threshold: 400
i2c_id: bus_a
transform:
swap_xy: true
mirror_x: true
mirror_y: false
on_touch:
- lambda: |-
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
- light.turn_on:
brightness: 100%
on_release:
then:
- if:
then:
- lvgl.resume:
- delay: 10s
- light.control:
brightness: 50%
- delay: 5s
- light.control:
brightness: 5%
lvgl:
displays:
- my_display
touchscreens:
- my_touch
buffer_size: 25%
color_depth: 16
pad_all: 0
border_width: 0
outline_width: 0
shadow_width: 0
text_font: font_s
align: center
style_definitions:
border_width: 0
align: CENTER
text_align: CENTER
pages:
- id: main_page
pad_all: 0
widgets:
- obj:
width: 480
height: 320
layout:
type: grid
grid_row_align: end
grid_columns: [fr(1), fr(1)]
# pad_row: 0px
# pad_column: 0px
pad_all: 0px
outline_pad: 0px
widgets:
- label:
text_font: font_m
pad_all: 0px
outline_pad: 0px
text: "Hello World"
- button:
grid_cell_row_pos: 2
pad_all: 0px
outline_pad: 0px
widgets:
- label:
text: "Test touch"
text_font: font_m
align: center
on_click:
then:
- dropdown:
grid_cell_row_pos: 3
width: 90
align: CENTER
options:
- Violin
- Piano
- Bassoon
- Chello
- Drums
selected_index: 2
dropdown_list:
selected:
checked:
text_color: 0xFF0000
Please let me know if you have any question
/Ghassan
Tommy,
Just noticed your question. I only check with this forum about once or twice a month
Happy to share but I mainly write in Annex32 RDS Basic these days - more powerful and much much quicker to program in. If you are still interested join the Annex RDS Forum (free to join) where I have placed the code already.
Since I have placed the code on this forum all sorts of improvement has taken place in the underlying BASIC including full support for the ESP32-3248S035C and R and many other screen based modules. If I see you there you can ask any questions.
I get an error when I try to install this with my display:
xtensa-esp32-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
*** [.pioenvs/display3-5/src/main.cpp.o] Error 1
ChatGPT says this is a RAM error, but I’m not sure of a way around it. Any thoughts?
Ok, I’ve made progress.
For reference, I’m using this board: Board: Amazon.com: AITRIP 1PACK 3.5" inch ESP-32 ESP32S ESP32 Display ESP-WROOM-32 Resistive Touch Screen TFT LCD Module 320x480 ST7796 ESP32-3248S035C Development Board for Arduino IDE : Electronics
Info: 3.5inch ESP32-32E Display - LCD wiki
Anyway, my current configuration is below. It works, but no entities show up in HA. I had to modify @ghassan 's code as my display is a resistive touchscreen, not capacitive.
esphome:
esp32:
board: esp32dev
framework:
type: arduino
logger:
api:
encryption:
key: !secret api_key
ota:
- platform: esphome
wifi:
ap:
captive_portal:
color:
- id: room_bg_color
hex: CCFFCC
hex: ff3399
hex: ff4e03
hex: FFFF00
- id: HA_blue
hex: 03a9f4
- id: color_grey
hex: D1D0CE
hex: A0A0A0
hex: FF0000
hex: FFFFFF
hex: FFFFFF
hex: FFFFFF
hex: 2F8CD8
hex: 1d5f96
hex: 03324A
hex: fff300
hex: FFFF00
hex: 006699
hex: 00334d
hex: 005782
hex: 0077b3
font:
output:
- platform: ledc
pin: GPIO27
- platform: ledc
pin: GPIO22
inverted: true
- platform: ledc
pin: GPIO16
inverted: true
- platform: ledc
pin: GPIO17
inverted: true
light:
internal: True
- platform: rgb
red: led_red
green: led_green
blue: led_blue
internal: true
spi:
- id: spi_tft
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
display:
- platform: ili9xxx
model: ST7796
spi_id: spi_tft
dc_pin: GPIO2
cs_pin: GPIO15
dimensions:
width: 480
height: 320
data_rate: 80MHz
color_order: RGB
transform:
swap_xy: true
mirror_y: false
mirror_x: false
touchscreen:
- platform: xpt2046
display: my_display
spi_id: spi_tft
cs_pin: GPIO33
interrupt_pin: GPIO36
transform:
swap_xy: true
mirror_x: true
mirror_y: false
calibration:
x_min: 200
x_max: 3900
y_min: 200
y_max: 3900
on_release:
then:
- if:
then:
- lvgl.resume:
lvgl:
displays:
- my_display
touchscreens:
- my_touch
buffer_size: 25%
color_depth: 16
pad_all: 0
border_width: 0
outline_width: 0
shadow_width: 0
text_font: font_s
align: center
style_definitions:
- id: default_style
border_width: 0
align: CENTER
text_align: CENTER
pages:
- id: main_page
pad_all: 0
widgets:
- obj:
width: 480
height: 320
layout:
type: grid
grid_row_align: end
grid_rows: [fr(1), fr(2), fr(2), fr(2), fr(1)]
pad_all: 0px
outline_pad: 0px
widgets:
- label:
text_font: font_m
pad_all: 0px
outline_pad: 0px
text: "Hello World"
- button:
pad_all: 0px
outline_pad: 0px
widgets:
- label:
text: "Test touch"
text_font: font_m
align: center
on_click:
then:
- dropdown:
width: 90
align: CENTER
options:
- Violin
- Piano
- Bassoon
- Chello
- Drums
selected_index: 2
dropdown_list:
selected:
checked:
