Automations created with this blueprint is not triggering as intended.
blueprint:
name: Plants low fertilizer detection and notification.
description: Regularly test all plant sensors with 'conductivity low' problem
and notify via Mobile App and Voice Assistants.
domain: automation
input:
check_time:
name: 'Time of the day to test on: '
description: Test is run at this configured time
default: '10:00:00'
selector:
time:
conductivity_threshold:
name: 'Threshold under which notification is triggered:'
selector:
number:
min: 0
max: 500
step: 1
unit_of_measurement: "µS/cm"
mode: slider
check_day:
name: Weekday to test on
description: 'Test is run at configured time either everyday (0) or on a given
weekday (1: Monday ... 7: Sunday)'
default: '0'
selector:
select:
options:
- label: Everyday
value: '0'
- label: Monday
value: '1'
- label: Tuesday
value: '2'
- label: Wednesday
value: '3'
- label: Thursday
value: '4'
- label: Friday
value: '5'
- label: Saturday
value: '6'
- label: Sunday
value: '7'
mode: list
excluded_plants:
description: Plant entities (e.g. cactus) to exclude from detection. Only entities are supported!
default: {entity_id: []}
selector:
entity:
domain: plant
# variables
variables:
day: !input 'check_day'
excluded_plants: !input 'excluded_plants'
threshold: !input 'conductivity_threshold'
hungry_plants: >-
{% set hungry = namespace( plants = [] ) %}
{% set allplants = states.plant %}
{% for plant in allplants if 'conductivity low' in plant.attributes.problem %}
{% if not plant.entity_id in excluded_plants.entity_id %}
{% if plant.attributes.conductivity | int < threshold %}
{% set hungry.plants = hungry.plants + [plant.attributes.friendly_name] %}
{% endif %}
{% endif %}
{% endfor %}
{% if hungry.plants|length >= 2 %}
{{ hungry.plants|join(', ') + ' have' }}
{% elif hungry.plant|length == 1 %}
{{ hungry.plants|join(', ') + ' has' }}
{% else %}
{% endif %}
# trigger
- platform: time
at: !input 'check_time'
# condition
condition:
- '{{ hungry_plants != '''' and (day | int == 0 or day | int == now().isoweekday()) }}'
# action
- service: notify.all_devices
title: Plant Conductivity Alert
message: '{{ hungry_plants }} low conductivity, consider fertilizing!'
group: plantfertlizer-notification-group
- service: notify.alexa_media
type: announce
- media_player.echo_main_bedroom
- media_player.echo_kitchen
message: 'Attention: {{ hungry_plants }} low conductivity, consider fertilizing!'
Automation:
- id: '1651426849206'
alias: 'Test: Plants low fertilizer detection and notification.'
description: ''
use_blueprint:
path: skepticautonetic/routines/plants/low-fertilizer-check.yaml
input:
conductivity_threshold: 100
excluded_plants:
entity_id:
- plant.dypsis_lutescens
check_time: '11:00:00'
check_day: '0'
Edit:
Add the automation part.
