Help me change my wake word
I hope someone can help me.
I had a fully working m5 Stack Atom Echo working with OpenWakeWord and the ‘hey Jarvis’ wake word. However, this was using an ESPHome yaml configuration I found somwhere in this forum.
After installing the 2024.10 update, HA reported that I should be using the satelite service? I wasn’t sure how to fix this.
So, I thought I’d start from scratch and install the ESPHome Ready Made Project Voice Assistant onto my m5 stack.
I have this set up and working and using the on device OpenWakeWord ‘ok nabu’. I guess this is the default.
I want to use ‘hey Jarvis’ but can’t seem to change it. I’ve changed the wake word in the settings for the preffered voice assistant pipeline - the ESPHome device is using the preffered voice assistant pipeline.
How can I change the wake word?
I’m seeing the same behavior.
I have Settings->VoiceAssistant->wakeword = Hey Jarvis
Did you try Settings->Integration->ESP Home->WakeWord = Local vs. HomeAssistant?
I’ll try that, maybe along with a reset & reinitialize of M5Stack, as wakeword was nabu when I setup M5Stack initially.
Hi @ItsMee
Yes, I have this set to ‘On device’
I have the same problem. Hoping a solution is found
same problem here
+1
Running HomeassistantOS on Virtual Machine. Piper, Whisper, Atom 5 Echo everything working fine with “ok Nabu” but no way to change the wakeword.
