I get this from time to time showing up in my home-assistant.log file. Can’t seem to see any pattern. Can anyone help me try to figure out if this is a bug or caused by something in my config? If it is my config (which I suspect), how can I figure out where my error is coming fromm?
2019-11-21 22:35:27 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/srv/hass-3.8/lib/python3.8/site-packages/homeassistant/components/automation/__init__.py", line 298, in async_trigger
if not skip_condition and not self._cond_func(variables):
File "/srv/hass-3.8/lib/python3.8/site-packages/homeassistant/components/automation/__init__.py", line 460, in if_action
return all(check(hass, variables) for check in checks)
File "/srv/hass-3.8/lib/python3.8/site-packages/homeassistant/components/automation/__init__.py", line 460, in <genexpr>
File "/srv/hass-3.8/lib/python3.8/site-packages/homeassistant/helpers/condition.py", line 387, in template_if
return async_template(hass, value_template, variables)
File "/srv/hass-3.8/lib/python3.8/site-packages/homeassistant/helpers/condition.py", line 367, in async_template
value = value_template.async_render(variables)
File "/srv/hass-3.8/lib/python3.8/site-packages/homeassistant/helpers/template.py", line 220, in async_render
return compiled.render(kwargs).strip()
File "/srv/hass-3.8/lib/python3.8/site-packages/jinja2/asyncsupport.py", line 76, in render
return original_render(self, *args, **kwargs)
File "/srv/hass-3.8/lib/python3.8/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/srv/hass-3.8/lib/python3.8/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/srv/hass-3.8/lib/python3.8/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 2, in <module>
File "/srv/hass-3.8/lib/python3.8/site-packages/jinja2/sandbox.py", line 440, in call
return __context.call(__obj, *args, **kwargs)
TypeError: 'bool' object is not callable```
