m.vladislav
(Vladislav Monakhov)
March 23, 2024, 4:52pm
1
type: custom:stack-in-card
mode: horizontal
cards:
primary: 'Воды в баке: {{ states(entity) }}%'
secondary: 'Температура: {{ states(''sensor.temperature_water'') }}C'
icon: none
entity: sensor.water_level
card_mod:
style:
mushroom-shape-icon$: |
.shape {
{% set water_level = states(config.entity) | int %}
{% if water_level > 95 %}
background: url("/local/water-level-png/water_level_3_100.png") no-repeat center;
{% elif water_level > 85 %}
background: url("/local/water-level-png/water_level_3_90.png") no-repeat center;
{% elif water_level > 75 %}
background: url("/local/water-level-png/water_level_3_80.png") no-repeat center;
{% elif water_level > 65 %}
background: url("/local/water-level-png/water_level_3_70.png") no-repeat center;
{% elif water_level > 55 %}
background: url("/local/water-level-png/water_level_3_60.png") no-repeat center;
{% elif water_level > 45 %}
background: url("/local/water-level-png/water_level_3_50.png") no-repeat center;
{% elif water_level > 35 %}
background: url("/local/water-level-png/water_level_3_40.png") no-repeat center;
{% elif water_level > 25 %}
background: url("/local/water-level-png/water_level_3_30.png") no-repeat center;
{% elif water_level > 15 %}
background: url("/local/water-level-png/water_level_3_20.png") no-repeat center;
{% elif water_level > 5 %}
background: url("/local/water-level-png/water_level_3_10.png") no-repeat center;
{% else %}
background: url("/local/water-level-png/water_level_3_0.png") no-repeat center;
{% endif %}
background-size: contain;
--shape-color: none;
{% if is_state('binary_sensor.water_level_full', 'on') %}
--shape-animation: ping 1.5s infinite, blink 1.5s ease-in-out infinite;;
{% endif %}
@keyframes ping {
0% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.7); }
100% { box-shadow: 0 0 5px 15px transparent; }
@keyframes blink {
100% {opacity: 0;}
ha-card {
border: none;
margin: 0px;
padding: 0px;
- type: custom:button-card
entity: input_boolean.water_pump_auto
show_name: false
styles:
card:
- width: 100%
card_mod:
style: |
ha-card {
border: none;
margin: 0px;
padding: 0px;
card_mod:
style: |
ha-card {
opacity: 90%;
box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.66);
margin-bottom: 10px;
mode: horizontal
cards:
icon: none
card_mod:
style: |
ha-card {
border: none;
margin: 0px;
padding: 0px;
.shape {
{% else %}
{% endif %}
{% endif %}
@keyframes ping {
@keyframes blink {
100% {opacity: 0;}
show_name: false
styles:
card:
- width: 100%
card_mod:
style: |
ha-card {
border: none;
margin: 0px;
padding: 0px;
card_mod:
style: |
ha-card {
opacity: 90%;
In one case, the map format is not applied, in the other, the icon is not displayed. How to do it right?
I didn’t mess with your background image logic but this is a fine approach. I added the blue border so you could verify it is working.
mode: horizontal
cards:
icon: mdi:mushroom
icon_color: red
card_mod:
style:
.shape {
{% endif %}
@keyframes ping {
@keyframes blink {
100% {opacity: 0;}
ha-card {
border: 4px solid blue;
margin: 0px;
padding: 0px;
m.vladislav
March 24, 2024, 8:55am
3
mode: horizontal
cards:
icon: none
card_mod:
style:
.shape {
{% else %}
{% endif %}
{% endif %}
@keyframes ping {
@keyframes blink {
100% {opacity: 0;}
ha-card {
margin: 0px;
padding: 0px;
card_mod:
style: |
ha-card {
opacity: 90%;
It’s not like that with me…
m.vladislav:
{% endif %}
My point was your background If statements are the issue so that is where you need to focus on your formatting. If you remove that code the animation works. When troubleshooting go simple, then get more complex.
You have two If statements under .shape
and that is causing your issues.
m.vladislav
March 24, 2024, 9:39am
5
mode: horizontal
cards:
icon: none
icon_color: red
card_mod:
style:
.shape {
{% else %}
{% endif %}
{% endif %}
@keyframes ping {
@keyframes blink {
100% {opacity: 0;}
ha-card {
border: none;
margin: 0px;
padding: 0px;
show_name: false
color: |
if (states['input_boolean.water_pump_auto'].state === "on");
return "green";
else;
return "red";
styles:
card:
- width: 120%
card_mod:
style: |
ha-card {
border: none;
margin: 0px;
padding: 0px;
card_mod:
style: |
ha-card {
opacity: 90%;
I copied and edited your code, and it worked.
{%endif%} seems to be everywhere in place, in which line is the error?
Even in the “button-card” it is not possible to change the color…
mode: horizontal
cards:
icon: none
card_mod:
style:
.shape {
{% set power = states('binary_sensor.water_level_full') %}
{% if water_level > 95 and power == 'on' %}
{% elif water_level > 85 and power == 'on' %}
{% elif water_level > 75 and power == 'on' %}
{% elif water_level > 65 and power == 'on' %}
{% elif water_level > 55 and power == 'on' %}
{% elif water_level > 45 and power == 'on' %}
{% elif water_level > 35 and power == 'on' %}
{% elif water_level > 25 and power == 'on' %}
{% elif water_level > 15 and power == 'on' %}
{% elif water_level > 5 and power == 'on' %}
{% else %}
--shape-color:orange;
{% endif %}}
@keyframes ping {
@keyframes blink {
100% {opacity: 0;}
ha-card {
margin: 0px;
padding: 0px;
card_mod:
style: |
ha-card {
opacity: 90%;
Mushroom and Button Cards use different templating. The Button card can change colors based on the state, but requires a different approach.
Two IF statements were under .shape
and that’s a conflict.
The button card portion
show_name: false
styles:
icon:
- color: |
return "green"
else;
return "red"
card:
- width: 120%
card_mod:
style: |
ha-card {
border: none;
margin: 0px;
padding: 0px;
m.vladislav
March 24, 2024, 10:37am
9
.shape {
{% if ... %}
{% elif ... %}
{% else ... %}
{% endif %}
{% if ... %}
{% endif %}
Is this code causing a conflict?
I found an error in my code - indentation before “.: |” and the subsequent block.
