OK so im stumped here, my living room lights (3 lifx bulbs in a home assistant light group) keep turning themself on for the last few days, and I cannot figure out whats causing it?
they just… turn on? I dont know why ?!
jk its still happening
Remove (x1) light from group and see if it continue on/off with others.
This will eliminate some possibilities
This could be not related to Home Assistant. 2 of my Osram bulbs have a tendency to turn on randomly without getting a command from HA (especially in the middle of the night). I never found the reason.
Don’t you have some power fluctuations/outages in meantime? Most of bulbs are turning on by design after the break… Sometimes it is confusing, since only some bulbs are coming on, but it might be related to just one phase having problems.
Turn on debug logging. Note the next time they turn on. Look it up in the logs and see what triggered it.
U had a rookie mistake where I left the entity field empty on a set state node with switch domain and turn_on function…turns out it was switching everything on as I set it
I have the same issue with few old Osram bulbs, it is extremely annoying, especially during night. Have you managed to find a solution? I’m pretty sure that it is not related to homeassistant but it is something with the bulbs itself.
it was something in node red that kept firing for some reason
