So this will be for video editing. I have a squishy budget of $2500.
Found these so far…
Add others if you know of something, but 64g memory 4T and a 4060GPU or better are a minimum.
I flipped a coin and heads won.
You figure out of that was A or B
So either that’s …
A: I looked at the link & there is no difference so get the cheaper one, or
B: I can’t tell from those words so it doesn’t really matter…
Probably b… But I gave you a 3rd option.
I heard you can run HA on a potato, so you can surely edit videos on a banana, right?
But I like option A better.
https://www.amazon.com/ASUS-Display-GeForce-Windows-G733PZ-XS97/dp/B0CWJR3HJ5/
Ryzen 9, how does that compare?
Intel a little faster…
https://cpu.userbenchmark.com/Compare/AMD-Ryzen-9-7945HX-vs-Intel-Core-i9-13950HX/m2064608vsm2033250
My biggest beef with Ryzen CPUs has been the core temp at load. Packed in a laptop with limited airflow, the heat from Ryzen has always been an issue for me. God forbid you actually put the laptop on your lap.
They were out of bananna’s today, I think it’s because I spelled it wrong, so bought the MSI today.
Thanks to those that voted.
