HELP ME! Samba errors on HassIO
From two o three hours Samba do not works
I use HA 0.64 and HASSIO 0.94 and my config is:
  "workgroup": "WORKGROUP",
  "name": "hassio",
  "guest": true,
  "map": {
    "config": true,
    "addons": true,
    "ssl": false,
    "share": true,
    "backup": true
  "username": "admin",
  "password": "admin",
  "interface": "eth0"
Hassio system log is:
18-02-25 21:10:37 INFO (SyncWorker_18) [hassio.docker.interface] Stop homeassistant/armhf-addon-samba docker application
18-02-25 21:10:38 INFO (SyncWorker_18) [hassio.docker.interface] Clean homeassistant/armhf-addon-samba docker application
18-02-25 21:10:45 INFO (SyncWorker_3) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-samba with version 3.0
18-02-25 21:12:52 INFO (SyncWorker_19) [hassio.docker.interface] Stop homeassistant/armhf-addon-samba docker application
18-02-25 21:12:53 INFO (SyncWorker_19) [hassio.docker.interface] Clean homeassistant/armhf-addon-samba docker application
18-02-25 21:12:54 INFO (SyncWorker_7) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-samba with version 3.0
18-02-25 21:13:17 INFO (SyncWorker_9) [hassio.docker.interface] Stop homeassistant/armhf-addon-samba docker application
18-02-25 21:13:18 INFO (SyncWorker_9) [hassio.docker.interface] Clean homeassistant/armhf-addon-samba docker application
18-02-25 21:13:19 INFO (SyncWorker_8) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-samba with version 3.0
Samba show me this log…
starting version 3.2.4
nmbd version 4.7.3 started.
Copyright Andrew Tridgell and the Samba Team 1992-2017
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
added interface eth0 ip=192.168.1.2 bcast=192.168.1.255 netmask=255.255.255.0
making subnet name:192.168.1.2 Broadcast address:192.168.1.255 Subnet mask:255.255.255.0
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
load_lmhosts_file: Can’t open lmhosts file /etc/samba/lmhosts. Error was No such file or directory
STATUS=daemon ‘nmbd’ finished starting up and ready to serve connections
smbd version 4.7.3 started.
Processing section “[config]”
Processing section “[addons]”
Processing section “[share]”
Processing section “[backup]”
INFO: Profiling support unavailable in this build.
No builtin backend found, trying to load plugin
tdb(/var/lib/samba/registry.tdb): tdb_open_ex: could not open file /var/lib/samba/registry.tdb: No such file or directory
tdb(/var/lib/samba/account_policy.tdb): tdb_open_ex: could not open file /var/lib/samba/account_policy.tdb: No such file or directory
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
tdb(/var/lib/samba/winbindd_idmap.tdb): tdb_open_ex: could not open file /var/lib/samba/winbindd_idmap.tdb: No such file or directory
STATUS=daemon ‘smbd’ finished starting up and ready to serve connections
waiting for connections
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 192.168.1.2
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 192.168.1.2
run_elections: >>> Won election for workgroup WORKGROUP on subnet 192.168.1.2 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 192.168.1.2
Samba name server HASSIO is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.2
im in the same boat and i admit im not the sharpest knife it the draw but i cant find any help for this i have been looking all week.
hassio loaded fine ssh works ok but samba just wont appear on my network
Same problem over here. Please give a update if there is any progress on this issue
