Hi everyone.
I’m very unfamiar with esphome lambda
I have YF-B10 G1"
Product Model YF-B10
Rated voltage DC=5V
Thread size : Male 1 inch
Flow rate : 2~50L/min
Flow Pulse: (6*Q-8) Q=L/Min±5%
Max. Working Current : 15mA (DC5 V)
Min. Working Voltage: DC 4.5V
Working Voltage:DC 5V~15V
Load Capacity: =10 mA (DC 5 V)
Operating Working Temperature : -25 Degree centigrade to +60 Degree centigrade
Liquid Temperature: 60
Accuracy : 5%~10%
pressure: >1.75MPa
I know that chatgpt is terrible at these things, but thought I’d 'give it a go
- platform: pulse_meter
pin: GPIO13
internal: true
timeout: 2s
accuracy_decimals: 0
total:
name: "Total Water Pulses"
unit_of_measurement: "pulses"
state_class: total_increasing
name: "Water Flow Rate"
unit_of_measurement: "L/min"
device_class: water
state_class: measurement
accuracy_decimals: 2
update_interval: 1s
lambda: |-
if (isnan(id(water_pulses_per_min).state)) return NAN;
const float litres_per_pulse = 0.00113f; // 9 L / 7,962 pulses
return id(water_pulses_per_min).state * litres_per_pulse;
name: "Total Water Used (Pulses)"
unit_of_measurement: "L"
device_class: water
update_interval: 10s
lambda: |-
if (isnan(id(total_water_pulses).state)) return NAN;
return id(total_water_pulses).state * litres_per_pulse;
I’ve conducted some water flow tests:
filled 9L in 1:30 minutes
Would be great if someone can provide what I need to put into the config
Much appreciated
