String does not equal the pattern of depreciated is the error code I get where did I go wrong?
the six lines related to the two lines below give me this error
white_value_command_topic: “LightMCU/glitterChance”
white_value_state_topic: “LightMCU/glitterChanceState”
# Example configuration.yaml entry
mqtt:
broker: xxx.xxx.x.xxx
port: 1883
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
cards:
- type: entities
title: Holiday Lights
show_header_toggle: false
entities:
- light.holiday_lights
- light.color_1
- light.color_2
- light.color_3
- light.glitter
- light.lightning
- sensor.current_led
script: !include scripts.yaml
scene: !include scenes.yaml
- platform: mqtt
state_topic: "LightMCU/locator"
light:
- platform: mqtt
command_topic: "LightMCU/power"
state_topic: "LightMCU/powerState"
brightness_command_topic: "LightMCU/brightness"
brightness_state_topic: "LightMCU/brightnessState"
brightness_scale: 255
white_value_command_topic: "LightMCU/modifier"
white_value_state_topic: "LightMCU/modifierState"
white_value_scale: 500
effect_command_topic: "LightMCU/effect"
effect_state_topic: "LightMCU/effectState"
effect_list:
- Color_Chase
- Color_Glitter
- Single_Race
- Double_Crash
- Rainbow
- Blocked_Colors
- BPM
- Twinkle
- Fire
- Fill_Solid
- Spooky_Eyes
- LED_Locator
retain: true
- platform: mqtt
command_topic: "LightMCU/ColorPower"
rgb_command_topic: "LightMCU/color1"
rgb_state_topic: "LightMCU/color1State"
retain: true
- platform: mqtt
rgb_command_topic: "LightMCU/color2"
rgb_state_topic: "LightMCU/color2State"
retain: true
- platform: mqtt
rgb_command_topic: "LightMCU/color3"
rgb_state_topic: "LightMCU/color3State"
retain: true
- platform: mqtt
command_topic: "LightMCU/addEffects"
state_topic: "LightMCU/glitter/state"
payload_on: "Glitter On"
payload_off: "Glitter Off"
rgb_command_topic: "LightMCU/glitterColor"
rgb_state_topic: "LightMCU/glitterColorState"
white_value_command_topic: "LightMCU/glitterChance"
white_value_state_topic: "LightMCU/glitterChanceState"
white_value_scale: 255
retain: true
- platform: mqtt
state_topic: "LightMCU/lightning/state"
payload_on: "Lightning On"
payload_off: "Lightning Off"
white_value_command_topic: "LightMCU/lightningChance"
white_value_state_topic: "LightMCU/lightningChanceState"
retain: true
